Screen went white stillhear audio
SOURCE: Bright white screen with faint images
If lighting did strike, you would be suffering power supply problems, due to a power surge from the strike.
The problem sounds like it could be related to the LCD panel becoming faulty or if your able to test inside the unit with a multimeter, you can measure the voltages from the printed circuit boards, especisly those suppling power to the LCD panel as well as the Logic PCB, A small printed circuit board you will find either attatched to the LCD panel. I hope this helps.
Good luck.
SOURCE: No picture
You have a bad Y sustain or bad Z sustain! End of story! Please feel free to give me a call if you would like more info!
I'll help u fix your TV!
Ask for Dave @ 1-503-432-9904 or message me @ [email protected]
SOURCE: I have an insignia lcd tv and the screen turned
Your TV requires repairs. Service can be obtained by calling 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada. If your product is within the factory warranty period, your repairs should be completed at no expense.
