Trying to get a word for the game Words with Friends
Call on the number for best solutions +1855(485)0407....
Type in your search bar : wordswithfriendscheatblogmybrain , then click on the purple choice that says "Click here for the smartest words with friends cheat blog." You will then get a blank words board and under that you enter your available letters, click the level you want and it will give you the best available word with points. then you go to your game and enter that word.
277 words can be made with these letters, cgaeirlr . Glacier is one of them. here is the full list: https://www.wordunscrambler.net/?word=cgaeirlr
Here are some words found on a website linked below http://www.allscrabblewords.com/unscramble/cgaeirlr
SOURCE: deleting old words with friends games on the ipad
Push and hold app until jiggliing with x.Tap x to delete from ipad.
SOURCE: Pass key on words for friends frozen can't get play button to work
Update your adobe flash software to the latest version:
http://get.adobe.com/flashplayer/
If that doesn't work then you probably have viruses and malware. Try malwarebytes anti-malware it's FREE and it's here:
http://majorgeeks.com/downloadget.php?id=5756&file=15&evp=693ee0b20204960edfd909666f809b26
Make sure to select the non-pro version.
Install and use TDSSKiller also (Also FREE):
http://majorgeeks.com/downloadget.php?id=6895&file=1&evp=6ee854ea7c22f46734f10d4e193d17ce
You can try Superantispyware as well (Also FREE):
http://majorgeeks.com/downloadget.php?id=5116&file=15&evp=4b877f10ddee47cecae8038a2f67054e
If
you don't have a good anti-virus program already you can use Avira.
It's FREE as well, just make sure to configure it to "Select All" Threat
categories. Here it is:
http://majorgeeks.com/downloadget.php?id=955&file=15&evp=b7cc93b8a46387032dd7756deb50bbbd
SOURCE: kindle fire will not load words with friends
Step one, download advanced task killer. It works great. When down loaded set the security level in the app to "low", the kill level to "aggressive", and the app kill rate to "whenever screen is off". reset your Kindle. (turn completely off, then back on) Try using your games again if that doesnt work then u might reinstall a game or two and see if that makes a difference. My fire did the same thing to me. Alot of time apps will run in the background and eat all of the RAM (memory) up and when you try to run games there isnt enough to do so. I had the same problem trying to play jetpack joy ride
SOURCE: words with friends cheat will not pick up correct letters
