Bell & Howell Splash Wp7 Waterproof Camera Logo
A
Anonymous Posted on Aug 27, 2014
<!-- from fixya rte -->How to open battery door? - Bell & Howell Splash Wp7 Waterproof Camera
Aaron
Level 1:
New Friend:
Problem Solver:
  • Contributor 1 Answer
  • Posted on Dec 19, 2014
Aaron
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
0
Helped
546
Points
Hold the camera upside down. In the middle on the bottom side is a small grey tab. Push and hold that down and at the same time slide the compartment door to the left. Its tight and might require the use of a knife blade wedged down in the crack between the arrow and the screw the first few times. Yeah it could be easier but it is a watertight seal remember. It only slides about a quarter inch then it opens towards you.
  • Aaron
    Aaron Dec 19, 2014
    Hold the camera upside down with the view screen facing you.
  • mike
    mike Dec 25, 2014
    thank you Aaron. This was not intuitive at all and I got no help from the direction book and the website.
2016 Lexus RX 350. Open locked door with dead battery on it.
Question edited for clarity and spelling of maker 'Lexis' to Lexus.
Question moved to model category.
Get underneath the engine and attach a battery charger positive to the positive lead on the starter and a clean bolt on the engine or bodywork. In 15 minutes, you will be able to open the door.
Alternatively there is the easy way, use the emergency door key that is hidden in the fob.
Manually Unlock Lexus - Dead Battery
youcanic https://www.youcanic.com > Vehicles > Lexus
Nov 6, 2023 - To unlock a Lexus with a dead battery, you can use the emergency metal key inside the keyfob to unlock the driver's doors. The instructions in ...
How to open the car or hood when battery is dead
ClubLexus https://www.clublexus.com > rx-4th-gen-2016-2022
Jun 6, 2019 - Driver door has a lock cylinder. Pull the physical key out from the fob and pull the driver door handle and look in the gap between the door ...
RX-350 Dead Battery, Mechanical key wont open - ClubLexus
Apr 19, 2022
HELP! dead battery and the car is locked - ClubLexus
Feb 20, 2009
Door locks operaton with a dead battery - ClubLexus
Jul 27, 2020
How to open the car or hood when battery is dead - Page 4
Jun 6, 2019
More results from www.clublexus.com ..
2answers
99 Corvette Headlights open and close for no reason When I'm driving down the road they will just pop up and a little while later close. Then I hear what might be a motor, Any suggestions? Thanks, Don
Could be the switch going bad or a short in a wire. If it had ever been in a accident that is where i would look for a broken or smashed wire.
Dead battery cant open doors
Unlock the rear door and climb in that way or call a locksmith to open the door for you
Audi central locking
Lock ALL DOORS, Disconnect the Battery... Wait 2-3 minutes and connect the battery and it should reset itself. Make sure all doors are LOCKED...
AND that you have a KEY to open the door in case it does not work.
How do I open the battery door
Open the battery door of what make and model camera?
2answers
Battery is DEAD on 2003 Ford Escape! Door key (using an actual key) unlock is also motorized, which needs battery juice. I can't get into this car! I thought about putting jumper cables on the sta
Open the door manually with the key!
Many Ford Escapes have power door locks as standard equipment. This system consists of a lock switch, lock actuator and wiring harness. When you depress the lock switch, it sends an electronic signal through the harness to the actuator. The actuator moves an internal piston that either pulls the actuator hook down or pushes it up. The actuator hook connects to the lock rod, which either locks or unlocks the door, depending on which way you push the lock button. While this system won't work with a dead battery, the mechanical lock system remains unaffected by electrical power loss.
Insert the door lock key into the driver's door lock.
Turn the key counterclockwise one quarter turn.
Pull the door handle up until the Escape's door opens. Once the driver door is open, simply open the remaining doors by pulling the interior door handles until the doors open.
Open battery compartment on outside battery base??? i want to change batteries on the unit but cant open door for battery??
I finally got mine open a few minutes ago by prying it with a knife. A thin screwdriver would have been safer.
1helpful
2answers
Car door opener not working..where is the battery? Is there one?
The remote does have a battery. It either has a small door that slides open or you remove a screw to separate the two halves of the case. The battery is inside.
Top Bell & Howell Video Cameras Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Bell & Howell Video Camera Expert? Answer questions, earn points and help others
