Samsung Galaxy Tab 2 7in. WiFi Tablet, 8GB Logo
A
Anonymous Posted on Aug 28, 2014
Galaxy 2 user manual
Doesn't take charge well...doesn't hold the charge lasts 2-3 hours only
Pam Spinks Chapman
Level 1:
New Friend:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Aug 28, 2014
Pam Spinks Chapman
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
15
Questions
Helped
1993
Points
29
How old is it? If it has had heavy use,may need new battery.
I need a download manual.
PDF]User Manual Manua - Verizon Wireless
cache.vzw.com/multimedia/mim/...galaxy_tab2/galaxytab2_manual.pdf
relating to the SAMSUNG Galaxy Tab, including but not limited to, ... network solutions selected by the software provider, solution provider or user. ..... 2. Push the 4G LTE SIM Card in gently to release the lock. 3. Carefully slide the 4G LTE SIM ...
Support - Wi-Fi Tabs GT-P3113 ' Samsung Galaxy Tab
www.samsung.com > ... > Galaxy Tab > Wi-Fi Tabs
Samsung ElectronicsVisit Samsung today for Samsung Galaxy TabĀ® 2 7.0 (Wi-Fi), 8GB. You'll find ... Manuals. User Manual ver.1.0 (EN, 4.95 MB). Jan 29, 2015. Download (pdf)
Support - Wi-Fi Tabs GT-P5113 ' Samsung Galaxy Tab
How can I get my Samsung Galaxy Tablet to turn on. The battery is fully charged.
There is usually a method such as holding the on button for a longer period of time. If it is easy to do the other thing that I've found with all sorts of "smart" devices which turn "not-so-smart" is to remove the battery for a minute or so, then put it back in. Many times the unit will turn on as soon as the battery is reinstalled and work correctly again after that. Last ditch effort, unless someone knows about the Galaxy, is a hard reset, there may be a reset button somewhere on the unit, I don't think the Galaxy has a reset button. If the unit still does not turn on it may need servicing.
1. Try the on button for 15 - 20 seconds if you know it is charged
2. Try charging for an hour or two then the 15-20 second hold on button, #1 above.
3. Removed battery (I'd measure the battery voltage while I have it out) wait ~1 - 2 minutes & reinstall the battery. If it doesn't turn on by itself try #1.
4. Nothing works start a service ticket with Samsung, URL:
http://support-us.samsung.com
You might try searching there as well for an answer to see if there's anything I missed.
2answers
Why will a samsung galaxy 2 tablet not charge?
first go to a mobile shop ask hif it it is the problem of battry or some hardware problem inside the tab and also check the charger weather it works or not
3answers
Why is my Samsung Galaxy Note 10.1" charging very slow.
There are a several reasons why the Galaxy Note 10.1 is not charging as much.
1. Too many application are turned on (check the task manager)
2. Too many notifications icon are turned on ( bluetooth, gps, wifi, etc.)
3. Plugging your charger using a computer
Are you using the original charger and plugging it into a wall charger?
How long did you use the Note 10.1 previous to noticing the damage? and was it extremely hot at the back?
If so, then maybe the battery isn't picking up from the charger. I've watched back to back movies while still using the charger but this can prove very devastating on the charger's outlet which became extremely hot after 4-5 hours or so of charging continuously. It turns out, the galaxy note 10.1 can withstand 8+ hours of ongoing movies but the charger outlet cannot. *If I didn't unplug it after 4-5 hours, the plug what have fried.
In this case, i believe the charger is more likely damaged than the Galaxy Note 10.1, which is more of a better scenario. Especially, since you charged it for over 24 hours, meaning it's charging something, but very slowly. Operating Galaxy Note while charging can prove detrimental in the charger's outlet and can in fact burn out.
I hope this info is helful,
Jason Chan
My samsung galaxy tablet 10 1 has been off for months i lost my charger Found one on amazon Plugged it in last night and the back light came on with the battery icon in the middle with a thinking timer in...
Plug it in to a USB on your pc or laptop. Let it charge for 1 hour then try holding in the power button while it is still attached to the computer.
for some reason samsung tablets like the charge from a computer or laptop better than mains power.
3helpful
Wont come on
Happened to me. My solution was to fully charge, then hold down power button for like one minute or more continuously. It causes some kind of restart. Last resource, Press Vol Down and hold, then depress power button and hold. This causes it to go back to reset mode. Good Luck.
Tablet 7.0 user manual
The manual is available on the product support page for the Galaxy Tab 2 7.0: http://www.samsung.com/us/support/owners/product/galaxy-tab-2-7-0-wi-fi . Scroll down and click on the Download button for the manual. You will need to accept the Samsung Terms of Use before you can download the manual. Samsung doesn't seem to list a manual for the gh69-15226d.
I hope this helps.
5helpful
6answers
My Samsung Galaxy Note 10.1 battery not charging can you please tell me why
Same problem on my Samsung Galaxy Note 10.1 (GT-N8013) w/ OS 4.1.2
It just boots up and shuts down.
1helpful
My galaxy tablet just went dark. No screen or power. It was more than 50% charged last I looked an hour before. It has been plugged in for 20 minutes now and it won't turn on. What happened??
it depends.. check the battery pack maybe this cause a over charge and check first if your galaxy tablet is still part of the warranty this will help you a lot.
Top Samsung Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
