The JVC HR-A34U only has an RF (antenna) input. You would need a converter for composite video, S-Video or component video to RF. I don't recall seeing a component video to RF converter. Amazon has several composite video to RF options. One is https://www.amazon.com/RCA-Compact-RF-Modulator-CRF907A/dp/B0014KKV7W . For this, you connect the Yellow (video), Red (audio) and White (audio) RCA outputs on the cable box to the converter. Then connect the RF cable between the converter and the VCR.
I hope this helps.
(These modulators were very common back when VCRs and video game systems first came out. Most TVs only had the RF inputs at the time and the video signals from the new devices had composite video only.)
I believe the JVC HR-S6800 is a VCR. Older VCRs have composite video outputs you can hook up to your TV.
Here is a good video on that.
http://www.youtube.com/watch?v=N9eP1ddtASU
Hi dave
To answer your question;
In order to watch both the dvd and vcr on the same tv input , you need to use the dvd/vcr output of your jvc.
The component output is for the dvd only.
So if you want to keep the component output for high definition when playing a dvd you can connect another rca cable from the dvd/vcr output of your jvc to another input on your tv when playing vhs.
If you want the owners manual online you can find it HERE
You`ll find all the info on page 11
Hope this help Good luck
I guess you are using the cable TV feed looped through the VCR to the TV set.
Make sure you did not confuse the in and out loop of the VCR.
In the VCR menu, or on the remote there is usually a button called TV/VCR (Video). Make sure it is in the TV mode to watch the cable. In the VCR (Video) mode, the TV must be on the VCR's designated channel to watch the VCR, and the VCR tuner is used to watch the cable channels.
Please explain what you mean by "tuning in." Are you referring to hooking up to your Television, or to a cable/satellite box? Or can you not see video when you play a VCR.
Check your hookup cabling. With a cable or satellite system, the VCR normally is hooked between the cable/sat receiver box and the TV. Cable box RF output to VCR RF input, VCR RF output to TV RF input.
There are other possibilities when your TV has video or line inputs.
Well from memory... you have to Plug in the Antenna to the Video, then from Video to TV, then ya Tune in the "Tuner" section of the Unit.. that outputs on ya TV, then you can simply press the record button(s).. also there is the option of Timer Recording... There was also a TV/VCR switch that had to be toggled on some models...
But ya really need a manual I believe the manual is at the below link...
www.sharefx.com/archive2.asp?offset=174400
The output freq of the vcr is sitting to close to an rf signal from a digi broadcast i guess,cross modulaion is the term.the rf can be moved away in freq to another bit of band width or if not using rf connection it can be switched off rf output altogether.find online vcr manual and find rf change section
Connect audio and video outputs of the playing camcorder or the audio and video input of the recording VCR. Set the recording VCR to AUX or Line Input setting. On most JVC VCR’s we use channel 0 for AUX. (F1 or L1 will appear on the front panel). If you have another manufacturers VCR, please refer to that owners manual for the proper setting.
