Recently when I scan a text document on 200 dpi to email, the file size is almost 1MB per page. I have changed the resolution and reinstalled the Scan Driver, but the file size is still too large. Previously, on the same printer, one page of text at 200 dpi would be ~300 kB. How do I reduce the file size for scans to email (given I have already reduced to resolution)?
An 8.5 inch wide document scanned at 200 dpi gives you an image that is 1700 pixels wide. This is almost enough to fill a fullHD TV screen at native resolution (1920 pixels wide) which is unnecessary detail. I would use any picture editing programme (many free ones available) to reduce the overall pixel width of your already scanned images by 50 percent. This will automatically reduce the 1MB image to 250k. If you can scan again, use 100 dpi to scan - the result is same; image will be half as wide (and long), and picture file size one quarter of the 200 dpi scan.
SOURCE: how do i make my PDF scan document small enough to email
This is a problem with most of these Fax Scanner Printers. You will always end up with a large file, like 10 mb for a simple file. I think no matter what you do with the scan, it is large.
Turn the color off and make it gray scale or black and white.
The best way that I have found it to work the best is a work around. Find a free fax service or one that is a few dollars a month. Hopefully you have a fax component on this and you can fax documents to the online service, it will turn that fax into a very nice PDF. You then configure the online fax service to email the to you. Now you can save for your records, rename it and email it to whomever you need.
E
