I have a problem when im printing it keep saying paper jam but there is no paper jam in the printer help
SOURCE: Always paper jam.
Check to see if something isn't blocking the paper path.
You could try cleaning the feed rollers as well.
SOURCE: laserjet 4345 mfp paper jam
13.20.00 can be also caused be a jam near the fuser (the part of the printer that gets hot to make the toner stick to the paper). Remove the toner cartridge and take a look for small scraps of paper along the whole path. Also open the door on the back of the printer and look for paper scraps from there. If you see paper stuck in the fuser, do not use anything sharp to remove it, be careful not to scratch the surfaces.
SOURCE: Paper Jam
Sometimes the "paper jam" with no paper is due to the printer not being able to feed paper in to the machine. You send a print job to it...printer attempts to feed paper but can't...then you get the paper jam message and ofcourse there is no paper in the machine. Powering off and on should clear the message. Make sure you clear the print job from the print que or the same thing will happen on power off/power on because the computer will still try to send the print job to the printer when turned on. I have found that all of HP's machines that have this style of paper feed mechanism fails prematurely. The pickup roller is too small for one but as soon as the roller is coated with dust it begins to fail. You can take a Q-tip and go in from the back to try and clean the roller. Water is fine.
Inkworks
866-381-0541
SOURCE: HP 4200 printer paper jam. No paper is jammed
check this out....when the printer reports the jam, open the paper tray very carefully and slowly.
Has the paper moved at all forward? Has it moved like 1/4 inch to 1/2 inch out of the tray?
If so, you probabaly need a torque limiter, no tools, $10 or so and a very very easy fix.
POBCM is very correct when he points out that the block/stop in the back of the tray moves when the tray is closed with too much force and this is the #1 cause most of the time.
You may see a "41.3" code displayed if the block is not up to the back of the paper and the paper is not all the way forward in the trays, and under the two metal clips at the front of the tray.
SOURCE: mY HP DESKJET PRINTER WON'T PRINT.iT KEEPS SAYING
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
