Switched it off last night light flashing but wont switch on
SOURCE: Samsung Plasma model ps-50p91fd red light
Hi:
First thing you should do is unplug the unit from the AC outlet and wait 5 minutes before pluging it back in. IF this does not solve your problem, then you should the unit serviced. The most common failure part in plasma's are the y-substain board and the power supply, have these check for shorted conditions.
I see so many here with no sound/no picture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signs of damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down the problem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the generic ones like Radio Shack). Many fuses are special even aside from amperage--Don't put a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses a standby power supply that runs 7/24 and a main supply (some are combined and some not.
Here aside from checking fuses you want to examine all the filter caps on the power/standby to see if any are puffed up or buldged up in some fashion--I attach a photo of a good one---top should be silver metal and PERFECTLY flat and have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating (saves money) which causes them to fail in a year or two---the standby runs 7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over. If set is opened at least look for puffed up and bad caps like in this photo.
