Sometimes it wont take a picture no matter whether I hold my finger down or tap it. It even balks when trying to turn it on or off. Shaking it or turning it sometimes lets me get a picture. Othervtimes it will take one pic and then I have to turn the screen off and then return back to the camera in order to get another picture. Needless to say, this is extremely annoying, especially when trying to capture spontaneous shots. Help?
Let's start with the basics first in order to solve your tablet issue. Once we go that, we can move forward as necessary.
I would recommend performing an antivirus scan on your device. You can search for "avast" or "malwarbytes" in your app store to get started.
If that doesn't work, then you can perform a factory reset as described by Samsung here: https://www.samsung.com/us/support/answer/ANS00062842/ . You'll be advised to back up your files before performing the factory reset.
Please let me know if this helped you or not.
SOURCE: Pen touch screen problem
Can you tell me if you can use the screen rotation on the left screen bezel and do you have all other pen capability, just checking to see if the drivers are right
SOURCE: how do i download pictures to tablet
Pandigital photo frames are an ideal way to display your collection of
digital photos. You can view photos with or without a computer using
just a memory card,
but it's always a good idea to transfer the photos you'll want to view
frequently to the internal memory of your frame. This is also a handy
way to back up your favorite images.
Transferring Photos from a PC
Copying Photos to Your Frame's Internal Memory
Next, open the folder in which you store your photos ("My Pictures,"
for example). Select the photos you want to transfer to your frame. Drag
them to the drive associated with your digital photo frame---this is
the "Removable Disk" drive you located within the "My Computer" folder.
Every photo you selected will then be copied onto your digital frame.
After the files are copied, disconnect your digital frame properly.
If you don't, your frame's internal memory could be damaged. Look for
the system tray in your desktop's
lower right-hand corner. Left-click the icon that shows a gray box with
a green arrow on top of it. Select "Safely Disconnect Hardware." A
dialog box will appear, asking you to select the device to disconnect.
Select the digital frame and click "OK." When the dialog box appears,
click "Close." You'll see a message in the lower right hand portion of
your desktop telling you it's safe to disconnect your frame.
SOURCE: my screen is frozen and it wont turn off
Low specs tablet sometimes will get this problem.Or just let it alone for a while, it maybe ok later. If not, it's better to contact the supplier for help.
Android 4.0 Tablet PC
SOURCE: My Samsung Galaxy Tab won't turn on, even though battery is full. What's the problem?
hi did you fix your problem?
