Question about Mtd Garden
Mtd riding mower steering shaft is stripped out
The steering shaft on my mtd model 13AN673G131 riding mower has stripped out gears and I need to replace it.
    New Friend:
  • 3 Answers
Go to WWW.MTD.COM they have the parts you need, most of the time. Depending on how old it is
Posted on Aug 29, 2014
6ya staff
SOURCE:
libaredneck
james
  • 125 Answers
SOURCE: MTD RIDING MOWER with 618-0229 transmission.
sounds like you need a new drive belt
Posted on May 04, 2009
panilling9
panilling9
  • 284 Answers
SOURCE: Need to remove rear wheels to replace tires on MTD riding mower.
most likely rust has taken over
find some liquid wrench or pb blaster and spray the axles liberally and let it penetrate the axles and wheel hubs where the axle goes through.
use a 2x4 and a hammer to tap against the wheel hub to try to move it down the axle then tap in back on to try to free it up as the penetrating oil works in, spin the wheel and tap in different areas of it
the worst case cenario would be to use a torch and heat the axle and hub up and drive it off, but it sounds as though you are moving it some and with some patience they eventually should come off
when you put them back be sure to coat the axle with some grease and do not forget to reinstall the key stock in each wheel, if they have it
the bolt in the center of the axle is all you need to remove and note where the washers came from and where they go back.
hope this helps you some
Posted on Jun 14, 2009
Stephen McGuinness
  • 143 Answers
SOURCE: mtd yard bug model - 198707 riding lawn mower blade belt size?
I dont know the belt size but if you go to mtd belts in Jackssmallengines.com you should find it. Stephen.
Posted on Aug 23, 2009
Michael Wheeler
  • 33 Answers
SOURCE: MTD riding mower does not move forward or reverse.
this is a belt driven transmission. from the engine driven pulley going aft towards the xmission differential there is another smaller variable speed pulley, there is a long belt between these two, from the variable speed pulley there is a larger xmission pulley that sits kitty-corner to it with a belt between these two. This larger "xmission pulley" is what drives the differential and depending upon which gear you have selected, makes it go forward or reverse. Check that both belts between pulleys are on, check that pulley's hardware is completely secured (nuts tightened down) The heads of these pulley's are splined to align to the shaft(s) and if they aren't tight, they will just spin and not engage the transmission. If your battery is under the seat, remove it and you should be able to see and access the aft pulleys. If both belts are on and engaging the pulley's and the shaft is turning on the transmission pulley than you have transmission differential failure. Bet it's the belt off or pulley head loose. Good luck, hope this helps
Posted on Apr 14, 2010
maxxer
  • 5 Answers
SOURCE: My mtd riding lawn mower won't go into gear...
Yes , this is what I had- the vari- pully was stuck and wouldn't move up or down and keep pressure on the belt. once I sprayed it with wd40 it started moving up and down ok- and would shift ok-
Posted on May 24, 2010
Have a 2010 sltx 1054 how do I remove steering shaft
Since have had to replace the hex bushing at bottom the shaft on an MTD. Recommend you putting back a bronze version instead the plastic version they have.
You should able to access the steering shaft lower though the underside of frame; easier if you remove the deck to give you space to work.You will need to remove the nut and gear. Then you should be pull the shaft out. If replacing the bushing pull just enough so you replace; no need to completely remove it from the mower.
May 13, 2015 | Cub Cadet Riding Lawn Garden Tractor 25hp...
How do I remove the steering shaft on mtd riding mower model 673
can you send picture of steer shaft top and bottom and middle i have to look at it
Aug 29, 2014 | Mtd Garden
Mtd riding mower steering shaft is stripped out model 13AN673G131?
not something easy to do... there is a bolt in the bottom of the shaft. there is a steering wheel that has to be removed. then the shaft lifts up and then you tilt it as you are sliding it out... heed my first statement
MTD tractor is "jumping teeth" on the drive shaft of steering as it doesn't mesh together smoothly either due to worn gears or improper spacing. Wheel thus spins with little catch in the gears to allow...
There could be several things going on with the steering gear. First check and make sure there is no debris or rocks caught in the gear. Then check the up and down motion of the steering wheel, it could need some shims under the shaft due to wear. Also check and make sure the bolt on the cross member is tight as well as the steering gear half moon. Another good resource for steering wheel shaft service is to go to MTD website ( service,mtdproducts.com/Training_Education/769-00947_SM_600_Series_Box_Steering_Shaft,PDF) This can be found at the MTD website under training and education and has a step by step instruction on servicing the steering system. This should get you rolling and cutting again.
Oct 30, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
MTD Lawn Tractor Model 13AM672G120 Steering gear broke, how to fix
Jun 03, 2012 | Mtd Garden
Steering is loose. How to tighten it?
Joseph, Most likely it is the bronze bushing at the other end of the steering shaft. You will need to remove the mower deck to access it more easily. The steering gear could be replaced at the same time if you want, you will be right there at both the bushing and the gear, the sector shaft hopefully is ok. You can view this with a flash light before disassembly. It is on the steernig shaft that goes behind the fuel tank, down into the frame. As you or a helper turn the steernig wheel back and forth, you can see the engagment of the steering gear and the sector shaft, to determine if they need replacing too. Your dealer should have a dozen or so of those bronze bushings. Its not a bad job to do.
Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Nov 09, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Got an MTD lawn tractor model # 137-752-300 need a left deck shaft, or the part # for a deck shaft that would fit that model
Sears has diagrams parts and pricing for alot of MTD products
I could not however find the model you listed.
Double check the model and then go here :
http://www.searspartsdirect.com/partsdirect/brands/Mtd-Parts
Jun 01, 2011 | Mtd Garden
I have a riding mower and the steering shaft goes to a deck,the phillips screw and shaft is loose but will not brake loose. there is a gear at the bottom of shaft and this turns the wheels it is not...
I have a yardman that had a similar problem, there is a spacer/gromit at the end of the shaft just above the gear this needs to be in place to hold the steering shaft straight.
Jul 12, 2009 | Mtd Garden
How to ajust drive belt on a mtd riding mower
Adjust in gear 7. If you try to adjjust in gear 1 you will get it to tight and it wont work properly
Apr 14, 2009 | Mtd Garden
Garden Logo
320 people viewed this question
Top Mtd Garden Experts
dannydoesita
Joseph Mueller
Joseph Mueller
p38arover
Level 1 Expert
Are you a Mtd Garden Expert? Answer questions, earn points and help others
