It said that asus F3jp can not be booted from neather one cd or usb except original which is instaled inside the laptop (OEM), is it true and if not how else to boot system again, have original 2 system recovery CDs but it won't boot from external CD ROM
I'm not sure about it. But many branded laptop did it to make sure you replacing the right part. Try to find the OEM parts from your friends and install it
The external CD ROM is it powered from the laptop or an external source?More than likely needs an externally powered optical drive
SOURCE: i am not able to boot my Asus EEEPc 1000h by the DVD
that's right. You can use external DVDRW drive and you must enter your DVD driver (usually you get it after you buy eeepc) into external. Cause your DVD driver include driver for eeepc and recovery windows for your laptop, just in case, your laptop get some crash on several software and get into factory default setting.
SOURCE: Asus Eee Pc 900 wont boot. no CD ROM comes with this computer
you have a usb port on your laptop if yes boot your system to format from pendrive go these site for more information
www.bootdisk.com/pendrive.htm
Testimonial: "give the 4 thumbs for a response. I think the computer boots..it turns on and whatnot...just wont load to the windows screen or anything"
SOURCE: I have a asus eeepc 900 netbook.suddenly it stop
Windows could not start because the following file is missing or corrupt:
/WINDOWS/SYSTEM32/CONFIG/SYSTEM
You can attempt to repair this file by starting Windows Setup using the original Setup CD-ROM
Select “r” at the first screen to repair
So then i click r at the first screen and nothing happens...It keeps on repeating to repair on and on with the same message after i clicked r. I can't even access to the window...what can i do???
SOURCE: reboot and select proper boot device and press a
hi...
set up your bios with boot 1st harddisk...
if that appaer again..check your hard disk..
tht problems occur becous your hard disk not detact.
thnks®ards
SOURCE: Unable to boot internal devices? bug?
Did you go into the bios settings and check the status of the hard drive? it would seem that is where the problem lies.
Testimonial: "I fixed problem myself... I downgraded bios to oldest version... pc now working... and u know what? *uck U ASUS! Asus bios files are bugy! My friends pc was good until warranty end.... after warranty pc started to do sh*ts.. I had to insert older version of bios??? TFW ASUS?? but thx for morale boost, good luck to you..."
