My Woods chest freezer is about 10 year old. The gree sees to be slightly flickering. Is this a concern?
SOURCE: Haier freezer chest not cooling. Green light is
Do not put a towel on your freezer or anything that could prevent a good seal from top of freezer.
jim
SOURCE: I have a GE chest freezer and the exterior green
Is this just a "Power-on" light to let you know it's plugged in and has power? This is probably just a "neon" (although the actual gas inside is hydrogen for the green color) bulb and sometimes they will do the flickering thing literally forever. In a way it's a good thing as it makes you look at it. If it really concerns you, or if it is actually a warning that something is going wrong (it should say in the manual, you DO have the manual don't you?) have it fixed under the warranty.
SOURCE: Red and Orange light staying on on my whirlpool chest freezer
try a total defrost,to clear any internal ice(every 12 months)then switch on and if you have a rapid freeze button leave on for 24 hours to get back to normal operating temp.if you have hard ice around the door seals then you have an air leak which you must sort out(try using a hot cloth to warm seals back into shape.....seals should fit all round, all the time.
SOURCE: Hinds do not hold the chest freezer door open, need new ones
Call 1-800-673-1262 Give model number.
SOURCE: RED TRIANGLE LIGHT STAYS ON CHEST FREEZER IS 10
defrost cycle is innactive, will ice up shortly and may not turn compressor off, defrost the unit totally(Turn off for 2 days with door open) and remove all water from the unit once done. Restart unit and should work normal for a week or so, ie...defrost cycle...get back to me if this is the case and will sort it from there, [email protected] Russ
