Move from park to drive on the gear selector but vehicle does move it self
SOURCE: 2000 ford taurus- wont shift into gear
first check drive axels , since you replaced front springs on struts i assume. it is possible that one of the axels popped out. next if thats ok check fluid level in trans with eng OFF should show over full make a srcribe mark on the stick. then START the eng it should go down to full or just below depends if trans is full or a little low . if level does not drop approx.1/2 in or so then have a transmission shop check for bad splines in torque convertor, that is a comon problem in that car, year and milage do not play a roll a large roll in parts failure in trans any more. not like it use-to.
SOURCE: sprinter gear selector
This is the gear linkages. It is a cable operated system to allow the gear lever to be dash mounted.
They are a common fault. The parts are about £65 from Mercedes (dealer only part) and unless you know what you are doing you can expect about 2 - 3 hours labour charge, though there are no special tools involved.
They average about 60,000 miles, though the replacements tend to be better.
SOURCE: Forced gear selector - now Spectra will not start
yes yes yes there s a newtral parking switch in those and you eitho bent or broke it off try puting the car in newtral not newtral you can see just go by feel shift the car into l1 try it then l2 try it
then d try it heck even try reverse and newtral
failing that you need a hays manual and a lot of time to crall arround eithor under your dash or hood depending what the book says
happy hunting and good luck
btw thats why all cars come with a parking or hand break dont be afraid to use it b4 you put your car in park it will save you a lot of problems in your tranny like bent parking pins from some moron bumping your car or just a hill or incline.
SOURCE: I have a 2003 trailblazer. The shifter or gear
linkage or cable is disconnected or brocken!!
cheers rob
SOURCE: 2000 Hyundai Elantra gear shift stuck in Park.
check for the brake switch if this doesnt work wont release from park if this ok then i will check the shifter cable check for power and ground
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html
Mercedes-Benz transmission sticks in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html
Mercedes Benz not engaging in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html
Chrysler PT Cruiser only goes in First gear?
http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html
Car is stuck in park and the shift will not move?
http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html
2007 Ford Expedition: How to shift car in neutral with Dead Battery
http://www.howtorepairguide.com/2012/11/2007-ford-expedition-how-to-shift-car.html
2002 Nissan sentra will not go out of park mode?
http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html
Nissan Sentra stuck in park?
http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html
Car will not come out of Park?
http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html
Automatic transmission will not go into high
gear?
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Car won't downshift sometimes?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html
Buick Park Avenue: Transmission will Not
shift into drive?
http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html
No
First gear Starts In Second Gear
http://www.howtobyme.blogspot.com/2012/07/no-first-gear-starts-in-second-gear.html
Ford Taurus won't shift from park?
http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html
2006 Ford F150: Will Not Shift out Of Park?
http://technoanswers.blogspot.in/2012/06/2006-ford-f150-will-not-shift-out-of.html
Car Transmission will not go into Park mode?
http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html
1998 Chrysler Voyager: Transmission Problem?
http://howtobyme.blogspot.in/2012/06/1998-chrysler-voyager-transmission.html
Shift indicator directly goes to 2nd when key
is turned ON?
http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html
Third gear missing and engine losing power?
http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html
Chevrolet silverado has whining sound in gear?
http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html
2002 Chevrolet Avalanche Z71: Gear shift
Issue?
http://whoisbyme.blogspot.in/2012/06/2002-chevrolet-avalanche-z71-gear-shift.html
Hard to shift gears on Manual transmission?
http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html
Car hard shift at slow speeds?
http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html
Transmission-Hard To Down Shift
http://technoanswers.blogspot.in/2012/07/transmission-hard-to-down-shift.html
Automatic transmission shift lever hard to move on cold
mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
2000 Nissan maxima shifts hard?
http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html
Vehicle noticed sluggish delayed shifts while
driving?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html
2007 Hyundai Santa Fe: Will not Shift out of
Park Mode?
http://schematicsdiagram.blogspot.in/2012/06/2007-hyundai-santa-fe-will-not-shift.html
These will help.
Thanks.
