SOURCE: lose sound on sony bravia 40v4100 lcd tv
if you are using an hd cable box it might be just that. what happens is if the cable company is doing work around your area or some one on your block adds another cable line to there house you end up losing signal for your box. now if you pull the power plugg and let it reboot that could either fix the problem temporarly or not at all. you might need an amplifier hooked up to your cable lines or a new cable box all together. contact your cable provider and ask for some one to test your signal quality. i am also assuming that your not getting the same problem when your watching a dvd. i hope this helps you
SOURCE: loud buzzing sound which is getting louder than
Most likely a capacitor going bad. If it gets louder after the TV had warmed up for a while, remove the back and blow all the dust off the circuit boards. While you're in there, look for a capacitor (google if you don't know what that is) right next to or touching another component, especially a resistor. Carefully bend it away a little to reduce heat transfer. If it's not a heat-related issue, it'd likely cost more than the TV is worth to have a repair shop fix it. Consider running the audio through a separate sound system. If it buzzes even with the TV volume turned all the way down, disconnect the internal speakers.
