Question about HP OfficeJet 6210 All-In-One InkJet Printer
HP Office Jet 6210 Horizontal Lines
I have an HP OfficeJet 6210 and I am getting hotizontal lines ONLY when I make a copy - this does not happen when I receive faxes. I have cleaned the cartridges and taken the back off and cleaned the rollers. I did find a piece of tape still in the back and removed it but the lines are still appearing.
Any help would be greatly appreciated.
  • mylan Nov 10, 2007
    It is NOT a black line, there are many vertical lines in clear - it just does not copy in those areas. In other words, on an 8 1/2 x 11 page only going on the glass to copy (not on faxes) there might be a dozen or more areas that no print can be seen. I will try this suggestion though...thank you.
    Genius:
  • 1,601 Answers
Black lines on scans & copies
Please perform Solution two: Clean the ADF rollers and separator pad, provided in the follwing HP web link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00228023&cc=uk&lc=en&dlc=en&product=421991
:) Dr Tony
May 14, 2010 | HP OfficeJet 6210 All-In-One InkJet...
When faxing on HP Office jet 6210 lines show up on the paper when it is recieved
Hi, The problem could be with the receiving machine and not yours. Here is a little test you can do, make a copy of a blank page and if the copy has line on it then it is your machine, if not then it is not yours. You need to open the top where the document feed through and clean the scanner glass with a moist rag, spots on that glass can cause lines.
Good luck, keep us posted.
Mar 13, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Can the ink cartridge HP 98 work on a 6210 HP Office jet?
No, it can't
The HP OfficeJet 6210 works with the following print cartridges:
Black: 94
Color: 95, 97
Photo: 99
Source: http://www.shopping.hp.com/supmodel/product/Q5801A
TechSaver!
Feb 01, 2010 | HP OfficeJet 6210 All-In-One InkJet...
I need an HP office jet 6210 paper tray
ebay.com type in HP Paper tray They are around 20 bucks and you could get it less then a week. hope this helps hun
Oct 24, 2009 | HP OfficeJet 6210 All-In-One InkJet...
I have a HP Officejet 6210 All in One, but I missplaced the CD
download your driver for free at official hp site: (copy and paste into your browser) http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=uk&cc=uk&h_page=hpcom&lang=en&h_client=S-A-R135-1&h_pagetype=s-002&h_query=HP+Officejet+6210+&submit.x=14&submit.y=6
Jun 14, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP office jet 6210 scanner failure error
have you tried to reset the printer?
(Take the power cord off hold # 3and then turn the printer on.)
That is an initial position problem
Parts are no longer available for this model from HP...
Jan 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Fax/ printer 6210 set up
Please see bellow is the diagram mentioned in the link bellow on getting stated up with your kind of setup:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu50333&cc=us&lc=en&dlc=en&product=421991
Good Luck
Sep 12, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Office jet 6210 - multifunctional
Open the back door & clean the rollers. Hope this helps.
Apr 01, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
181 people viewed this question
Ekse
Thomas F. Schneider
