I have a Fisher & Paykel Intuitive washing machine coming up with the error code 105, do you know what this means and how to fix it? Thanks.
That is a communications error between the display board and the motor control board, unfortunately this can be caused by 3 things the first is the drain pump which needs to be tested with a multi meter before proceeding, then it will be a matter of plugging in a display board and/or a MC board, you only need one but they cannot be tested the only way to find out is to change them one at a time
SOURCE: IW712- fisher paykel intuitive eco.
I BELIEVE THAT IS A ROTOR SENSOR ERROR
REPLACE THE ROTOR SENSOR
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
SOURCE: fisher and paykel intuitive washing machine not spinning
to remove the pump - remove power pins. Press bayonet clip in [lhs of pump base. Twist anti clockwise. Remove blockage. Rub a smear of Vaseline on seal before re assembly
SOURCE: Fisher Paykel Intuitive Eco Washer - IWL15: what is error code 136 on a fisher & paykel IW...
fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
