When i go to run a wash cycle the sign F 26 appears and the system begins to beep
SOURCE: kenmore frontloader washing machine making roaring
Your rear bearing is bad. Check warranty to see if rear tub is still covered.
SOURCE: kenmore washer
This is a known problem with the Oasis. It is caused by a bad relay on the Interface Control Board inside the console. Unfortunately, the "cure" for the problem is the replace the board and/or the wire harness that connects the console to the Main Control Board underneath the console. If you attempt to defeat the sound on the circuit card you could potentially damage it to the point where it doesn't work at all. The circuit board usually runs about $120. The only inexpensive alternative is to leave the room and shut the door behind you. That way you won't have to deal with the annoying beeping.
SOURCE: repair front load washer
wash machine not draining properly at end of wash. not fully spinning.
pls advise
SOURCE: Kenmore HE2 Frontload Washer will Not go into spin cycle
Could be that you have something in the pump. Remove the bottom panel by removing 3 screws and you will see a round cap facing you in the center of the washer at the bottom. there will be alot of excess water behind this cap so get ready with plenty of towels. Unscrew the cap as you would the gas cap on your car and all the water in the lines and in the machine will come out here. Inside here you may find a number of things. Some of the things I have pulled from them are ...coins, socks, pencils, underwear, underwires to bras. The list goes on and on. Or you may not be using "he" detergent. Use only "he" powder detergent. Use vegetable oil to remove excessive sudds build up then use 2 cups of vinegar to clean the machine on whitest whites seting.
SOURCE: Maytag Fronload Washer Error Code FH
take the lid off attached to the inlet valve to the dispenserr you will see a little white mechanisim in line with them. this is called your flowmeter take it off and blow through it is should sound like a cazoo. put it back on and try to do a wash cycle. if this doesn't help you need a new flowmeter. also if you take the kick panel off you will find the tech sheet to help you diagnose this problem. Always first check your hoses if you have flood hoses get rid of them next get a bucket and see if water is comeing out of the hoses next check you inlet valve screens see if there is sand in them if there is clean them.
