Need to setup my system i can not find my manual to hookup my wires. i need help to do that
Not sure on the exact model number these sites may have the manual but not sure on model number so cannot be certain
http://www.hifi-manuals.com/Nakamichi/Soundspace-10-service-manual/download
http://www.nakamichi.user-manuals.com/nakamichi-c-68.html?page=1&sort=2a
http://www.user-manuals.com/user-manual-NAKAMICHI-1000II.html
SOURCE: Nakamichi SoundSpace 8 System
check your power cord, check your 9 prong relay cord from power amp to deck unit, check your fuse that is in a little slot in the plug itself, most importantly check the 9 prong plug to the control unit itself, if you are mounted on the wall it could easily come out enough to not make connection. these units will take alot of bad voltage errors, if the only thing not working is your cd player you should still be able to eject it, if not it is power related, if it will eject but not play then your drive band is broke and unless you are very very mech minded take it to a repair shop who is nach. refered just look online for service try my ideas 1st you might get lucky, I hope I am right!!
SOURCE: Nakamichi soundspace 11 dvd
The problem you have is that of the roller of the dvd player.The roller is one the moving back and port bringing the lense set,the roller is dirt already the grease thier is hardened already.Its needs to clean so that performance will come again.By using a lighter fluid to clean and lense is wipe by a cotton with no chemical use.When you do this your player will read again.
