We have an upright 3 door fridge freezer which is 19 months old but we have noticed the bottom freezer now gets a layer of ice on the bottom. Why?
SOURCE: layer of ice forming on bottom inside of freezer - Samsung fridge freezer
might have the temperature too high .. buy a freezer thermometer and place in freezer
SOURCE: Whirlpool Freezer
your defrost drain is frozen remove the rear bottom panel on the freezer at the back insede the freezer and clear the defrost drain there will be a hole under the ice you just need to clear the drain not buy a new freezer
SOURCE: LG frost free fridge freezer GR-359sq
defrost drain is blocked - probably with ice. take the back panel off inside the freezer and melt the ice off with a hairdryer then follow up with hot water till it flows away freely. this takes some patience. if fault reoccurs then get back to me
SOURCE: Upright freezer door inside developing ice
The door seal is at fault. Regardless of the small tear it is not sealing well.
Take a dollar bill and close it in the door. Then pull on the bill to feel resistance.
You will find it pulls easily in some place. That is where your air leak is that is causing the condensation.
Do this about every 6 inches all the way around the seal.
SOURCE: kenmore freezer upright frost build up on door
first just take it out and clean that one carefully .And then set correctly and observe it,s working condition.then also it's not working means show it to ur near by worker those who repairs it
