It will run for a while then cut off john Deere x34)
CHECK GAS FOR WATER THEN CHECK MAKE SURE GETTING GAS CHECK PLUG WHAT DO THEY LOOK LIKE WHEN CUTS OFF DOES IT LOOSE SPARK REPLACE COIL IF DOES 80.00 IF NOT GETTING GAS REBUILD CARB ALSO CHECK FUEL FILTER BAD THING ABOUT TRACTORS IF YOU LEAVE THEM OUT SIDE UNCOVERED THEY WILL GET WATER IN GAS ALL OF THEM SO DRAIN GAS OUT PUT IN NEW ALSO DRAIN CARB OUT ALSO CHECK OIL LEVEL IT HAS A OIL CENSOR ON IT THAT REEDS OIL LEVEL IF OIL LEVEL NOT SAFE THEN WILL SHUT IT OFF TRY THIS LET ME NO WHATS HAPPENS THE RED NECK
SOURCE: john deere runs then stops
I fixed my mower stalling issues on the L111 by loosening the gas cap. I ultimately drilled a hole in the gas cap and screened the hole. Sounds ridiculous but without that venting the engine would run approximately 20 mins and die. It was also much more difficult to start the next time. Something else to pass along to whomever might view this... I replaced the cranking battery with a battery that had allot more cranking amps and I no longer had hard start issues ( this was after I vented the gas cap). Hope this helps.
