To copy names and numbers to the
SIM card
1 Select Menu > Contacts.
2 Scroll to New contact and select
Options > Advanced > Copy to SIM.
3 Select an option.
When you copy all contacts from your
phone to the SIM card, all existing SIM
card information is replaced.
To automatically save names and
phone numbers on the SIM card
Options > Advanced > Auto save on
SIM.
3 Select an option.
To save contacts on a memory card
Options > Advanced > Back up to m.
card.
SIM contacts
SIM contacts can contain names and
numbers only. They are saved on the
SIM card.
SOURCE: cant copy the numbers from my phone to my new sim card
this problem is due the sim space may be u have 32k or16 k sim . so memory is nt enough to save all the contacts - so do these things to solve ur problem .. 1) if u have an alternative sim which is 64 k sim then copy all the contacts in that sim then transfer them to ur required phone afterwards ... 2) if u any other alternate phone than transfer half the contacts in first atempt than transfer rest the contacts in other atempt...
SOURCE: Sony Ericsson Z525A-COPY PHONE NUMBERS TO SIM CARD -BLANK SCREEN
to retrieve your numbers you would need to follow these key strokes...
center, toggle down (1 time), center, toggle up (2 times), center, toggle down (5 times), center, toggle down (5 times), center (3 times)
then wait for quite some time...it takes a while to copy all of the contacts...I would say anywhere from 5 to 10 mins...
this should work to save your contacts.
To save your pictures (and any other data you might want to retrieve) you could buy Sony's data cable for the z525a. I haven't tried this but it should work since that is what the cable is for.
Its called a DCU-60 USB data cable, and is listed as being compatible with the z525a.
SOURCE: sim card pin code? where is it
hey friend you have to unlock your phone to your regional network
go on this site www.unlockitnow.com
pay some money then unloack your phone online
