The fuser may need to be replaced. Sometimes that code can be reset in service mode without replacing that part.
Service mode--- Additional functions button, then hold down the 2 & 8 key at the same time, then Additional functions button again gets into the mode. Then select Function, Clear(CLR),Error(ERR) then hit ok and cycle main power. If it resets-great. If not,you need a fuser.
SOURCE: i have canon ir3300 errorcode is E000740-0003
E740
0001 At power-on, the LAN card has a fault.
0002 The MAC address has a fault.
0003 The LAN card cannot be read.
Main cause The LAN card is faulty. The main controller PCB is faulty.
Action
1. Connector
Is the connection between the LAN card and the main controller PCB normal?
NO: Correct the connection.
2. LAN card, Main controller PCB
Try replacing the LAN card. Is the problem corrected?
YES: End.
NO: Replace the main controller PCB.
SOURCE: canon ir3300 is giving me error code E6002-0003, h...
Turn off the copier using the power switch on the right. Turn it on again holding 1 and 9. You should see rectangles on the screen. Once this is finished the copier should be in download mode (If this process hangs or doesn't get started the disk will need to be replaced by a tech). Once you reach download mode you'll need a tech to flash the hard disk to get the copier going again. If this doesn't work, the hard disk will need to be replaced. In any case your hard disk is dying and will need to be replaced soon.
SOURCE: what is canon iR3300 error
Hold down the 1 & 9 buttons on the keyboard and
turn the machine on using the switch on the side of the machine
hold down the buttons till the screen goes black a white square appears now take you fingers off and let the machine run untill the screen is filled with the white boxes. turn of and on and hopefully that will fix it. the error is caused but the hard drive being currupted. if this does not fix it then the hard drive needs to be replaced by a canon service agent.
what you need to do is just resetting your machine.
1. Press * 28 * on your machine in a quick move.
2. Select copier
3. Select Err.
4. Select Clear then press O.K
5. Turn your machine off for 1 minute and turn it on again.
The error code will not be there anatmoreand your machine will be functioning well.
