Is there a driver out their that makes this projector compatible? i am using a VGA to HDMI cable on a new macbook pro 10.9.4
SOURCE: Can you connect a Mac ProBook laptop to a ProxTrax Multiverse?
Hello. There is no "device" needed to connect the units together...You'll need a cable that is"mini display port to vga". In order to connect the projector to the laptop, the cable has to have the special Apple connector which fits into a specific socket on the back of the laptop. The other end is just a standard vga connector which is plugged into the computer input on the projector. Hope I helped you!
SOURCE: Sanyo PRO Xtrax Multiverse Projector powers on but no reflection appears
broken lamp?? check for little cracks in the bulb bar.
If lamp is discoloured( dark grey), overheating is cause, no cooling after using the PJ.
SOURCE: Sanyo Pro Xtrax Projector
not all computers are F4 - some are F7... - If there is not a small graphic on each Function button - just press and hold your function button and I'd start with F3 then F4 then F5 and so on - often your image will appear on the projection screen and disappear from your laptop - just re press Function and the appropriate key - you may also need to change your display - go to your control panel then display then settings and you will want 1024x768 - as far as cables you will need a male VGA that will plug into (usually blue) connection on your laptop and then depends on what type of projector you are using - it may take a VGA or RGB (5pin cable ~ red green blue horizontal vertical) make sure that in your menu settings that you have it set to the same as the input you have plugged into
