Factory reset tablet
Steps on how to do the restart. -You have to turn off the system. -Then press and hold the power button until you will see a message that will popup in a window that saying "Device Options"Appears on the screen. -Then select the power off again then you can see it again.You can be able to check that it first. -Then just select okay And while holding down the -Back -Button -Then Press and hold the power button. -Until you see the Coby`s Logo -Then wait until it change to Android Logo. - Then press the Back button.And Then the system menu will appear in the screen. -And then choose the wipe data/factory reset. >Home >Menu Buttons >Press the back,the button once you select the wipe data/factory reset then just click option. Then the confirmation that you will see in the screen Is a "yes" "Option". Then Choose "yes"-delete all user data,option by using the "Home"and "Menu"buttons. Then it will perform the factory data reset. -wait until it done. -Then once your done the main system menu has to appear in the screen. -And then reboot the system. -Then you have to press the back button to reboot the system. -The system will reboot the initial factory data setting. -All the user data will be lost. -Then Give the reboot,at least for 5 minutes. -Then Do not assume the unit has frozen.
SOURCE: Ii have the Coby 7005
Hi, I am Steve, lets help solve your issue.
I am afraid the information you have been given is completely wrong. There is not such thing as plug and play in the android world. Android was initially developed for use on embedded devices and as such had no need to recognise external devices automatically. Version 2.1 (as installed on your device) is now quite old and cannot support it. Even the new version (froyo -2.2) does not support it.
Your device does come with a built in wireless adaptor, so you don't need a USB wireless adaptor.
SOURCE: Coby touchscreen internet tablet for android will
I would guess that it overheated. You aren't supposed to leave them plugged in for extended periods of time.
SOURCE: my android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
