The camera is not a stand alone system. It is designed to work with the rest of the surveillance system, in this case the Uniden UDW10003 and UDW20055 Video Surveillance Systems. The surveillance system has software for reviewing footage and that software is clearly for a PC rather than a phone. The service department may be able to advise you further regarding the tablet, given there is a wireless feature to the surveillance system.
ARE ALL YOUR FIELD CAMERA'S POWERED UP (1ST) , OLDER SYSTEMS POWERED THERE FIELD CAMMERA S FROM EXTERNAL POINTS (UNLIKE MODERN UNITS THAT ALL POWER COMES FROM BASE FOR FIELD UNITS)
You need to hook this unit up to a computer to record and install the optional software that came with it....you can then set up record times, intervals, etc...
Good luck.
Try putting the key in the key cylinder but do not turn it at all. Then try and remote start the car. If it works then your bypass module is bad and needs to get replaced.
