SOURCE: Panasonic PT-50LC13 reset hour meter
on the tv itself push the volume down button and at the same time using the remote control press the pip button. I just did this on my tv - had the same problem. it worked perfectly. Jeanne
SOURCE: Need kit to repair panasonic PT-50LC13 ballast
Check partstore.com to find the kit. The kit part number is LSUC0022.
Testimonial: "Very good source, thanks for the fast service!"
SOURCE: panasonic pt-50lc13 shutting off
i'm on my 3rd bulb in 5 yrs. i hate this tv. this time my bulb light didn't come on. instead the power light flashed green fast then went to red flashing after. i took out the bulb and it's blown!
SOURCE: panasonic model# PT-50LC13
It very well could be the ballast. I unfortunately have this tv and keep extra bulbs because they go out about once a year. Last time when I replaced the bulb the tv blinked and the red lamp light flashed like it does when the bulb is bad. Ballast repair kit fixed it up. This is certainly a design issue but you'll get no help from Panasonic. If tv comes on the goes out after a while, clean the fan filter.
SOURCE: how to reset the lamp on a panasonic tv pt=50lc13
I think you hold down the volume - button on the TV and the SPLIT or PIP button on the TV remote at the same time for 5+ seconds. Becareful that your arm does not block the remote from getting to the TV. A message will appear when you are successful. Best wishes.
