Question about Lisle Serpentine Belt Tool
<!-- from fixya rte -->Witch way do i turn tensioner - Lisle Serpentine Belt Tool
Remove/replace serpentine belt
there is a belt tensioner that you need a long handled ratchet to adjust then simply take old belt off and put new one on of buy one here Search results for serpintine belt tool
Mar 12, 2015 | Cars & Trucks
Engine overheating problems
Neither. TGhe seprentine belt drives the engine's water pump. If you are lcuky, repalce tghe defective idler pully on tensioning ar,m, install new belt and pray!
Mar 02, 2014 | Buick LeSabre Cars & Trucks
Serpentine belt
sounds like belt tensioner might be worn out.check to see if belt has tension after u install
Sep 29, 2013 | 1998 Ford Escort
There is no nut on the tensioner,just a weird looking thing witch a socket won't fit
Belt tensioner? Usually takes a 3/8 " ratchet or 3/8 " breaker bar to rotate the belt tensioner.
Get in there with an inspection mirror(It's tight quarters!).
Some Toyota's require a skinny wrench to fit onto the 14 mm bolt head.Some are 17 mm.
Socket won't get in there.
Some cars require loosening the engine mount and jack the engine up to gain enough clearance!(Mitsubishi)
Feb 21, 2013 | 2004 Toyota RAV4
What makes a belt squeak?
Belts squeak for the same reason tires do when they spin. They are slipping. Something isn't turning as fast as the belt wants it to. On ford it's usually ether the idler sprocket or the tensioner. If you remove the belt and try spinning all of the pulleys by hand.( note the crank wont spin freely) you will usually be able to tell witch ones slipping.
May 14, 2011 | 1999 Ford Taurus
Cant find a way to losen belt to change altanator
9b71416.gif 1 is the belt tensioner, use a 3/8" breaker bar or surpentine belt tool to rotate the tensioner. Insert tool into the square hole and push to the right and the belt will loosen and can be removed.
May 22, 2010 | 2001 Ford Escort ZX2
Hi we have a kia sedona 2000year and 2.9 diesel, exec. auto. it came with half the engine in the boot, we have skimed the head and rebuilt it just the new cam belt just wont tighten enough we have fully...
the cam belt should have a little slack in it,, about 1/2 inch over its longest run, its not like a fan belt witch should be tight, but check the idler bearing are not worn out,,and i do hope this is a new belt for this car,,,if your using the old belt,,,dont! fit a new one on it or it could brake on you, and that would be another engine rebuild on your hands,,,
Mar 07, 2010 | 2003 Kia Sedona
I need diagram to show how to tighten belts on isuzu rodeo 95 hav a sqeeking belt dont know witch belt???
Loosen pulley nut on tensioner and then adjust tension screw, tighten nut back when done
Nov 08, 2009 | 1995 Isuzu Rodeo
My drum will not turn .GLER642C
if your drum is'nt turning does your dryer power on ? if so then you have a bad or broken drive belt that needs to be replaced or it has slipped off the drum or out of the tension pulley if the rest are good or you have a bad tension pulley witch rarely goes bad. if it is your belt and you can't find a replacement let me know i can find one for you.
Mar 27, 2009 | Dryers
1993 ford probe belt slipped off how to tension
your car may have information around in engine comparment is a diagrama of the belt how to put it back on. you have to have a tensioner pulley witch you gatta use a tool to depresset the tension so the belt fit right
Jun 20, 2008 | 1993 Ford Probe
Lisle Serpentine Belt Tool Logo
215 people viewed this question
Top Lisle Hammering Experts
Robert Wooley
Robert Wooley
john h
Lawrence Oravetz
Are you a Lisle Hammering Expert? Answer questions, earn points and help others
