Refrigerators Logo
A
Anonymous Posted on Sep 03, 2014
Why is aSide by side fridge leaking brown liquid from below ice maker?
We have an approx. 10 yr old side by side Frigidaire PureSource Fridge, model number FRS23R4CW2. The last several days, there has been a small stream of brown liquid coming from under the "frame" where the ice maker and water dispenser is. If you press on the tray, like where you would sit a cup to fill it with water, a small amount of the brown liquid in the tray, but mostly it drips under the frame, down the fridge to the floor. As far as I can tell everything in freezer is still frozen, water still works and ice maker works. Any ideas?
  • Official Brand Answer 2,267 Answers
  • Posted on Sep 09, 2014
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1288777
Points
2557
Thank you for your post, friend!
I understand that you are seeing a brown liquid come from under your dispenser area. I would recommend you having a professional come out to your appliance to check and assure the water lines are connected properly and not developing any moisture problems to form from under your dispenser. I hope this is helpful. -Matt
5 Related Answers
A
Anonymous
  • Posted on Dec 02, 2007
SOURCE: Leaking icemaker
You may want to check that your water line isn't cracked.
Ours cracked and now we need to replace our floor. The water line is too close to the compressor which heats the plastic tubing and makes it brittle. Our refrigerator is 9 years old. Model #TPX24BRYFBB
Good luck
Anonymous
  • 143 Answers
  • Posted on Jul 23, 2008
SOURCE: Neff K3990 Fridge Freezer ice maker not working and water leaking out
Sounds like the water hose to the ice maker has come loose. Is it in warranty?
Anonymous
  • Posted on Nov 17, 2008
SOURCE: GE Profile side by side fridge - water dispenser doesn't work
More than likely, your water line is freezing up in the door. You can remove all of the ice cubes and lower the freezer temp to about 3. Leave the freezer door open for about 5 minutes or so and if this does not work, leave the door open a little longer. Also, disconnect the water line at the base of the freezer door, near the floor, and press the dispenser lever. If you have water there, you most likely have a frozen line in the door. Changing the water filter often will help but it is not the answer and is can get quite expensive. By the way, Make sure to hold the dispenser lever forward for at least a couple of minutes each time you test for water flow. If you do not get water at the connector at the base of the door after you have disconnected the line, you have a problem with the valve in the back of the refrigerator.
Anonymous
  • Posted on Jul 03, 2009
SOURCE: leaking fridge
my maytag had cloged defrost drain cleaned drain all ok
kel1guy2002
Kelly
  • 3740 Answers
  • Posted on Mar 27, 2010
SOURCE: maytag fridge water dripping from inside freezer side
This sounds like the evaporator drain may be clogged either in the freexer compartment or at the outlet to the drain pan under the unit. Every defrost cycle the defrost element makes water by melting the ice on the evaporator coils. If the drain is clogged there is no other place for the ice to go. Many times the drain may just have ice buildup in the evaporator drain funnel that can be corrected with a manual defrosting.
To do this manual defrosting all you do is first unplug the unit then remove everything from the freezer compartment. After that place a fan blowing into the freezer section for a little over 2 hours. Please NOTE this will make more of that pesky water mess so be ready to tend to the mess as it presents itself.
After the 2 hour fan session plug the unit back in and reload the freezer compartment with previous content. Monitor for the possibility of the water manifeting itself again.
In addidtion to the above there is a drain pan catch basin in the bottom of the unit near the compressor. They are usually white plastic on Maytag units and not to rugged. Make sure that the drain pan is not loaded with debris. There is about a 1/2 inch diameter opaque plastic line that drains into the catch basin. That is the Evaporator darin tube. Ensure the very end of the tube does not have caked up debris in the very end of the tube. Sometimes this tube cakes up and then the debris dries hard inside the tube near the end. Make sure the tube is free of foreign objects and clean.
After all of the above / cleaning and clearing / manual defrosting it is still making water then most likely the lower panel under the defrosting element / evaporator may have become disconnected allowing defrost cycle water from the melted ice into the freezer compartment vs exit via the drain. To fix the disconnected power metal panel problem the rear freezer panel would have to removed to re-attach / repair the metal panel that guides the water into the evaporator drain.
Thanks for using FixYa.
Kelly
My 4 yr old whirlpool side by side stopped making ice. I replaced parts but no success.
The water fill tubes might be bad with your fridge and there is a problem with the water tubes too which will need to be replaced as well.
1helpful
Why are only drawers in fridge cold & not making ice?
Contact a professional. Sounds like either your damper door is not operating correctly and not letting enough cool air from the freezer enter, or there is an air leak that is making ice form .
Water is slow to dispense. Takes forever to get a glass of water? Ice maker seems to be keeping up? 5 yr old professional series in a 5 yr old house?
Try replacing your water filter. If that does not solve it you could possibly have a problem with your water valve or where the water line connects to your house water system.
Ice Maker on Whirlpool Side by Sidek stopped making ice
Go to sears.com, select "Parts Direct", enter model number and wait for unit to be displayed, find ice maker part number and price.
Frigidaire fridge leaks where ice maker is on
Your leaking problem gives two possibilities. The water control valve for the ice maker side is defective and while shut off the water will continue to slowly flow and leak into the freezer compartment. The other possibility id the condensate defrost drain is blocked and frozen over behind the rear panel of the freezer and at the bottom of th coils. I believe your defrost condensate drain has a blockage of ice and will need to be defrosted and clean the condensate line from the freezer to the condensate collection plate below your refrigerator. Most times the blockage begins slowly until the opening of the drain hole under the evaporator freezes itself shut. Below is a link to some solutions I have collected over a period of time. Also has a short movie that makes the repair look simpler. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
click on link below
1helpful
Hooked up waterline to side by side frigiedaire,
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Kitchenaid 8-yr old fridge wanting to upgrade icemaker
Check out this site - it gives a toll-free number to call to ask for exactly what you want. Unfortunately I have not been able to find any alternative ice makers advertised or discussed, but speak direct to frigidaire and they will keep you up to date on any new products. http://frigidaire.stores.yahoo.net/
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
