Generac 5847 XG8000E XG Series 8000 Watt Electric-Manual Start Portable Generator CSA Compliant Canada Logo
A
Anonymous Posted on Sep 03, 2014
Where is the spark plug on my generac xg8000?
charles beach
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Generac Master 1,917 Answers
  • Posted on Sep 04, 2014
charles beach
Generac Master
Level 3:
Renaissance:
Answers
1917
Questions
Helped
570397
Points
3010
Baried in the motor hard to get to but if you take tank off you should see it good luck
1helpful
2answers
I have a natural gas generac 8kw it was running fine now it will not run found that out after the last power outage pull the plug looks good found that it will not spark at the plug
How old is it???? Does it have a read out that tells you what's wrong?????When is the last time you did a maintaince tune up on it???? Mine is fueled by propane and I changed the oil and plugs and it's been fine since....Sometimes it's the starter/ignition..I would do a complete tuneup first, then clear codes, then try starting it up manually....If that works put it back on auto..Good Luck
I have a generac mc alternator model -38 6938 my voltage pulsates underamload just started any ideas
Cleaned and adjust carburetor per Repair Manual. then adjust governor repair manual and should take care of problem on this old generator.
https://www.generator-parts.com/manuals/generac-rv/051834.pdf
There is no spark to the plugs on my generac 12000 watt generator,i replaced the plugs and still no spark,any help would be appreciated.
Unplug the oil sensor.
The oil sensor is located behind the oil filter. I unplugged the oil sensor and it fired right up. Plugged it back in and it runs fine.
It might be because it is cold.
I don't know why but I turned it off and it starts right up now.
Generac mc-35 wont start no spark at plug
make sure magneto is VERY close to the flywheel. Like, two pieces of paper close.
What's the mag or coiul on a generac 6500 generator 13 hp
The "mag" is a magneto and it generates the high voltage pulse to fire the spark plug. The "coil" is about the same thing but it uses a set of points or an electronic ignition to control when the spark is delivered.
1helpful
Generac ix 2000 does not start. checked spark plug and it is good. oil good.
what a **** generator, worked for 100 hours and now wont start anymore.
did all the checks and replacing of spark plug and oil etc, simply wont start, ****, ****, ****..... service is horrible too. they just give you the runaround.
5helpful
2answers
20KW Guardian Generac does not produce 12 volts to run engine
The problem is that the printed circuit board inside the generator draws a little current from the battery even when the generator is not running. Over the course of a few days this can make the battery weak enough to be unable to get recharged by the built in running charger which results in not enough power to run the electronic governor on the generator. Usually the spark plugs will work even with a fairly low battery.
Most of the Generac generators come with a built in trickle charger that runs off of the transfer switch load terminals. If your built in charger isn't doing the job it's either broken or you have the wrong sort of battery installed in the generator.
Regards,
Carl
Top Generac Electrical Supplies Experts
vince
Paul Bade
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
