Have you applied pressure to top or bottom edge? Probably one of fine vertical connection lines are broken. Almos unfixable. If you received the screen like this, consider taking it back for warranty.
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - 2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Apr 15, 2015 - 7 posts - 4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Solid vertical line means you have bad LCD panel due to failed TFT driving circuits.
This VX series are not built as well as the old Viewsonic used to be.
you must reset the system of you TV.Open the back cover of your TV reach for the main board.there is a small button on the main board just press it and the error of your TV will be ok...
I had a similar issue. Took it in and apparently i had 4 bad capacitors and after replacing those, my tv was perfect. But I think I lucked out on this one. :) try it.
