How do i set mms setting on m moto q9m or the right connections to send or receive mms messages
Jason-
What service provider are you trying to use the phone with?
If Verizon, this should be by default in the phone's settings. Ensure it is enabled on your plan.
Your Service Provider may be able to push the settings through the network. I don't believe there is an option for MMSC settings on the CDMA phones.
Mark
Motorola Support
SOURCE: Motorola A1200 MMS Problems
Internet Setting T-Mobile
T-MobileWeb Settings:
Primary IP Address: 216.155.165.050
Secondary IP Address: (Blank)
Access Point Name (APN): wap.voicestream.com
Data Bearer: GPRS
Profile Name: GPRS
Username: (Blank)
Password: (Blank)
Home Page: http://wap.myvoicestream.com
Picture Messaging Settings:
Multi-Media Service Center (MMSC) Address: http://216.155.174.84/servlets/MMS
Validity Period: 72 hours
Hide ID option (if option exists): set to off, no, or disabled
SOURCE: ActiveSync Not Working
it might be trying to configure a microsoft exchange sync thats why its giving you that message you may want to try and uninstall activesync and download the lastest verizon 4.5. during install do not click on check box that says connect to exchange server and try to sync again, should get you taken care of,
SOURCE: Motorola q9m shuts down
maybe a phone issue but you can always try to reset the phone to see if that helps, ( power phone off, hold center button, power phone on keep holding center button until master reset screen comes on) , or most carriers like verizon and alltel i know have an update you can download and install from motorola.com ( click on support and then software downloads) may ask for purchase date cust put in a recent date and download is free. both reset and update will erase alll info off phone so back up first before you do them
SOURCE: how to setting gprs in moto rokr e6
You can only set the Internet/WAP/MMS Profile, IF you got an Active Internet on another SamePhone with the Same Service Provider. In short, its very difficult to set Manually.
The Best Option is to Call your Service Providers they will first Inquire the Brand i.e; Motorolla and Model i.e; Roker E6, Thats it, you will receive a PUSH Message, save it, restart you Phone, Enjoy Internet.
If I was Helpful, Kindly Do Rate!
Regards.
You should check MMS profile setting. The proper setting should be configured before sending or receiving MMS. To retrieve the MMS automatically, you should set the settings at "Auto download" settings. To check,
1. Go to Message from the idle screen.
2. Go to "Settings" and then "Multimedia messages."
3. Select "Receiving options" and "Home network."
4. Go to "Foreign network" menu and check the status
5. If it is set at "Auto download", you can receive MMS automatically.
6. If it is set at "Manual", you should operate MMS retrieve function manually.
