Print does not fall within form lines
SOURCE: kyocera printer problem
First I would recommend cleaning the printer. When you change the toner there is sheet of paper that comes with the toner cartridge that explains how to properly clean the printer. If you do not have that handy, there is a panel on the left hand side of the printer that you need to open. Once the panel is open you will see the waste toner bottle; leave it in place. Above and to the right of the waste toner bottle will be a green nob. Pull this green nob slowly in and out three or four times. This will clean the charging wire. Next underneath the green nob there should be a piece that looks like a rectangular box when you pull it out. I believe it is green as well. This is the charger grid. With each toner you should have gotten a small slate blue box with a plastic lid that has a piece of felt under the plastic lid. Remove the lid and this should slot in under the long, rectangular charger grid. Move this back and forth three or four times and than remove the slate blue box. Gently push the charger grid all the way back in and close the access panel.
If this does not fix your problem I would recommend getting service from wherever you purchased the printer as you may have damaged the drum.
Let me know if you have any further questions.
Henry
SOURCE: Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
SOURCE: Kyocera FS 1010 printer. Not printing even with new cartridge
may be moisture.just switch the dehumidifier on for some tine.
SOURCE: Kyocera FS-3900 and FS-4000 Prints very faint. New printers affected
sounds good
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
SOURCE: the 3rd light on my Kyocera FS-1020d is flashing red, no printing
The flashing is a code. Depending on if it is flashing fast, slow or so on...
Turn to page 32 of this manual for more information.
If you are satisfied with my answer, be sure to click on the "Thumbs-Up". If you have further questions, please feel free to ask them. Thanks for using our service!
