Need to know how to change Timex watch battery Changing Timex watch battery is not hard but care must be taken when doing so If you are not careful you can damage the watch...
Either a loose connection inside or it just needs a new battery. They can be power hungry depending on how you use it and what battery technology type was used in the last one.
watchesoftoday.comhttps://watchesoftoday.com > Blog
A Timex watch battery will last between two and five years, depending on how often you use the Indiglo feature, while the watch itself can easily last five to ...
? 2:44 https://www.youtube.com/watch?v=x_C7VsE8Kks
Jun 26, 2015 - Uploaded by Lin Le
Timex Triathlon Ironman Watch Battery Change, I forgot to show you how to reset the "AC" with tweezers so ...Missing: cr2016 sr526sw
Oct 15, 2010 - Wondering how do you change a CR2016 battery in a Timex Idiglo watch? Changing a CR2016 battery in a Timex Indiglo watch is not a hard ..
Depending on when you bought your Timex, you shouldn"t need a battery just yet, your Timex came with a good battery. Look under the stem (winder) for a small piece of plastic that is not allowing the stem to go all the way down, remove that piece of plastic and push the stem down and your Timex will start. Or if your Timex has buttons, look for a tab of plastic on the back cover, this tab of plastic is keeping the battery from (ground) a complete circuit remove this tab of plastic to start your Timex. Changeing the battery while fairly easy, you"d need jewelers screwdrivers and of course the new battery, Best Bet, look for a small watch repair shop in your area for the battery change.
If you don't have the proper tools I recommend that you not do this yourself. You could scratch the case or damage the movement if you don't know what you're doing. If it's a water resistant watch the gasket also needs to be replaced once it is opened. DO NOT reuse a gasket! For about $8 any watch or jewelry store can change the battery and renew the gasket for you.
Timex suggests that you have a watch repair person change your watch batteries. I think it would be a good idea to try and replace the battery, but if that fails to work, contact Timex for advice. If they suggest that you should replace the entire wath, keep the battery. I have no guarantee that any of that would work, though.
