Question about Sylvania 6427TE 27" TV
How to connect sanyo dvd and vcr combo player DVW-6100 to older tv
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 70 Answers
On older tv sets there are limited inputs...one for video and one for audio..
Find the white output hole for video on the back and run the cable to the set, and as for the audio there will be 2 red output holes (left and right on your dvd/vcr combo unit) this will use a special cable you can buy at radio shack that converts the left and right to just one output(it's like a "y" looking chord. it will still work if you just use one audio chord "out" from the dvd/,vcr unit but you will be hearing only one side of the "Stereo"
plug these into the back of your old set the white is for video and the red is for audio.
Posted on Sep 15, 2014
2 Suggested Answers
Anonymous
  • 66 Answers
SOURCE: I need a code for this TV/VCR/DVD combo CT202SL8
Call your manufacturer or go to the website. You can retrieve those remote codes by phone call or @ website.
Posted on Aug 07, 2009
yammy_alf
wenceslao alfar
  • 666 Answers
SOURCE: HOOKUP A MAGNAVOX DVD/VCR PLAYER TO TV AND DISHNET WORK CA
may be your tv systems don't have an accessory for audio video input. but you can hookup that by using an RF modulator adapter, this is a converter from audio / video to RF signal and connected directly to your antenna connection. you can purchase that RF modulator adapter to an electronics store.
Posted on Apr 18, 2010
Is the Sanyo dvw-6100 compatible with a smart tv.
Yes, assuming that your smart tv has the appropriate audio inputs that can be fed by your Sanyo.
Sep 06, 2016 | Sanyo DVW-6100 DVD Player/VCR
How to hookup Sanyo DVW-6100 to a Sylvania tv
If the Sylvania tv is a CRT (old style tube tv) you can just use an RCA cable and hook it into the composite video. It will be the cable that has a red, white and yellow connectors on it. The yellow is the video, the red is the right audio and the white is the left audio. Connect ones side of this cable to the output of the DVD/TAPE player and to the input on the TV side.
Sep 04, 2014 | Sanyo DVW-6100 DVD Player/VCR
How do you record a t.v. show using the VCR on a Sanyo DVW-6100 combo?
Use a "1-to-2" splitter on the cable between the output from the Direct TV box and your TV. Connect 1 of the 2 to your TV.
Connect the other cable to your VCR.
Apr 26, 2014 | Sanyo DVW-6100 DVD Player/VCR
I don't know where to put the yellow, red and white connectors on the TV or the dvw
look on the back of your flat screen , there is a panel with inputs , example: VIDEO 1 , VIDEO 2 , etc. , connect your yellow , red & white from the DVD COMBO to video 1 (input) there colored to match with your cable , yellow w/ yellow , red w/ red , white w/ white , hope this helps AJ
May 08, 2009 | Sanyo DVW-6100 DVD Player/VCR
Question
Yes those players sell for around $399 depending on the source. You can google your brand and model # and put prices at the end and it will search for different sources and different prices.
Jan 26, 2009 | Sanyo DVW-6100 DVD Player/VCR
Sanyo dvd/vcr
please provide correct model number of your Sanyo product to help you out or check user manual at Sanyo Support.
Sep 25, 2008 | Sanyo DVW-6100 DVD Player/VCR
Sanyo dvw-1600
The motor for the DVD drive may be busted. I reccomend getting a new DVD/VCR Combo. otherwise, your dvd player is basically fried
Sep 03, 2008 | Sanyo DVW-6100 DVD Player/VCR
Hooking my dvd/vcr up to my television.
Easy Answer! connect to composite cabels to the ports underneath the words "DVD/VCR Out" for a Coaxial, use either the component ports or connect a coaxial cable from the port labled RF Out to the one on your television.
Aug 30, 2008 | Sanyo DVW-6100 DVD Player/VCR
Hd tv to vcr
What model and manufacturer DVD/VCR combo are you using. if it has a HDMI port, you should buy a HDMI cable to your combo player than to your HDTV (most don't have this High Definition port.) 6f3606c.jpg
 otherwise, it probably contains a composite port, connect the red to the red (Left) white to white (mono) and yellow to yellow (Video) than connect the wires to the matching port on your HDTV) then switch the input to AV or Composite. 9701d83.jpgb5e3eb0.jpg
If this fails, you need a coaxial cable.85dec5e.jpgconnect a coaxial cable to your player then to the coaxial port on your tv. change the input to "either Coaxial, Cable 3 or any input that sets it to coaxial input.
Mar 24, 2008 | Sanyo DVW-6100 DVD Player/VCR
Dvd player will not work
how can i connect my cable tv to the vcr
Dec 30, 2007 | Sanyo DVW-6100 DVD Player/VCR
Sylvania 6427TE 27" TV Logo
109 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Caltronic TV Repair
Caltronic TV Repair
Level 1 Expert
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
