LG Flatron L1715S 17" LCD Monitor Logo
A
Anonymous Posted on Sep 03, 2014
Why won't my white balance change to yes it's been like this a few days now.I change it to yes & it changes back to no instantly?
Singer stylist 534 sometimes when you stop won't start without turning balance wheel
Yes this is normal especialy with heavier fabrics. It allows more control so you build up speed gently. It is also related the limited power of the motor.
Only one channel going to b/w
Not the tv,it the brocasting incoming signal cable have a slice matalic contacting to that procise prequencies problems for that channel.Take another tv used it,with that incoming signal for that channel for a few days.See,if have a same problems have happen to another tv?Yes,than call the Cables,Dishes or Telicoms compannies,change that section of the incoming of broscasting signal cable line.Not,than take a piece of sand paper about 1000 grits,rub the input metal pin a few times,to have it better contact.
1helpful
When i take a picture it looks red , I took in to wal-mart and they told me to send it to you all
thats very helpfull of them??? they dont have a clue do they?
unless your using a red filter to take photos with its this part playing up
all digital cameras and camcorders have whats called a built in
"white balance meter",,,and yours is not working right,,,
the white balence meter is to let the camera see what colour light its seeing in,,,, the colour temperature of sun light on a bright sunny day is 6600 begrees kelvin,,, in an electric light buld is about its about 3500 degrees kelvin or less? if you took a photo in sunlight the camera sees anything white in the photo "as white" and is happy to print it as white,, but in electric light buld it sees "white" as "red" this is due to the drop in colour temperature, your eyes can also see this (but your brain has its own white balance meter built in) what the white balance meter will do is change what it records or see's to take out the red and make it look white insted,,by changing the clolur temprature of the light its taking the photos in try this out,,,
take a white sheet of paper,, go out side on a sunny day and take a photo of it,,, if its not white and it looks a bit red its the white balence meter playing up in the camera,,,
yes i know,,, you hate me now? its as clear as mub "A"
Oct 26, 2009 • Cameras
1helpful
White balance on D50 set correctly?
Are you saying that you're using a white background but it doesn't appear white in the pictures? If so, then yes, you need to change the white balance to match the light. Probably "tungsten" but you could try different settings and pick the one you like best or you could use a white piece of paper and set a manual white balance.
Cannot shoot outdoors
well most likely the white balance is set for indoors or dark. what you need to do is find out how to change the white balance on the camera and then it should be fine
Casio Exilim
Yes you got it right. You have changed the white balance setting of your camera. Adjust it and it will be back to normal..
Nikon D200 / photos coming out magenta somtimes blue
Set it to a manual white balance colour temperature, 5200K being an average one to start testing at. Does this make a difference? If not, then the sensor, RGB lightmetering sensor or exposure board may be at fault. The peripheral area of most sensors is used for white balance metering, which denotes a sensor issue, although if the exposure board isn't reading this information correctly, then it will give varying results. However, Nikon's 420 pixel RGB sensor on the D200 may also be taking WB readings. I'll be talking to Nikon soon, but try manual settings first.
White Balance
What is White Balance? The human eye captures white as white, red as red and blue as blue, regardless of whether you are outside under the sun or inside under incandescent lighting. Although this is something that we take for granted, the human eye actually adapts to correct the changes in color under different light sources. In reality, when light sources vary, colors caught as the reflection of those light sources also vary. For instance, films for cameras that use film are designed to capture the most appropriate coloring outside under the sun. Thus when you take pictures under incandescent or fluorescent lighting without using a flash, the colors in the resulting picture may seem strange. Digital camera and digital camcorders are equipped with a handy feature called "White Balance" that corrects the changes in color under different light sources, just like the human eye. One of the white balance settings, "Auto White Balance" (AWB) automatically adjusts to correct the changes in color under different light sources. White Balance and Coloring The White Balance feature on Canon digital cameras and camcorders is set to "Auto White Balance" at the time of purchase. If you prefer different coloring, if you want to adjust the coloring more in detail, or if you want to change the coloring on purpose, we recommend that you change the white balance setting.
White Balance
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
