Question about Lisle Serpentine Belt Tool
Serpentine belt diagram 1997 jeep grand cherokee limed
6ya staff
SOURCE:
motor1258
Mike Butler
  • 6674 Answers
SOURCE: need a diagram or routing picture for serpentine
Posted on Jan 10, 2010
Anonymous
SOURCE: Serpentine belt diagram for 1994 dodge caravan v6
For two long days I tried to get help on the internet but all I ended up with was a virus. I ended up getting a diagram from a local parts store,and it didn't cost anything.
Posted on Feb 11, 2010
Patrick Rayome
  • 1757 Answers
SOURCE: Changing a 1997 Toyota Corolla Serpentine Belt
Click on the following Link. It has the Belt Diagrams you will need.
http://www.2carpros.com/car_repair_information/year/1997/make/toyota/model/corolla/1997_toyota_corolla_drive_belt_routing_diagram.htm
Posted on Mar 11, 2010
Patrick Rayome
  • 1757 Answers
SOURCE: What do I need to
For the 1997 Dodge Grand Caravan Serpentine Belt:
Did not specify what Size Engine: 2.4L, 3.0L 3.3L, 3.8L.
Click on the following free direct Link. It has several of the Serpentine Belt Diagrams and Tensioners that are possible with your Size Engine (2.4L, 3.0L, 3.3L, 3.8L) and engine options (AC/No AC, etc.).
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.Com!
http://www.2carpros.com/car_repair_information/year/1997/make/dodge/model/grand_caravan/1997_dodge_grand_caravan_drive_belt_routing_diagram.htm
"HOW TO":
Standard Rules to Removal the Serpentine Belt with an Automatic Tensioner:
1. Find the Tensioner(s). (See Diagrams on Link)
2. Using a Serpentine Belt Tensioner Tool, Or Wrench OR Ratchet, Rotate/Move the Tensioner USING THE AVAILABLE NUT (on the Pulley or Arm Base) OR the OPENING (3/8ths or 1/2 inch square opening) rotating the Tensioner Pulley/Arm - moving it away from contact with the belt and towards the area where the belt is not in contact with the Tensioner Pulley. The Tensioner is spring loaded, and is hard to rotate/move.
3. Remove the loosened belt off one of the other more easily accessed Pulleys.
4. DO NOT quickly release the Tensioner, but gently allow the Tensioner to rest in its closed position.
Standard Rules for Installing the Serpentine Belt with an Automatic Tensioner:
a. Pick a Pulley that is most easily accessed. This will usually be on top. This will be the last Pulley that the belt will go on.
b. Using the Diagram: Install the new Serpentine Belt on the remainder of the Pulleys....over, under, left right.
c. Using a Serpentine Belt Tensioner Tool or Wrench or Ratchet Tool: Rotate/Move the Tensioner Pulley/Arm "away" from Belt contact area on the Tensioner. This spring is pretty hard and with a new belt, it will be even harder to install. Rotate/Move this to as-close to the maximum allowed inorder to have enough slack in the belt to get it up and over the last pulley.
d. Using your other hand - Pull the Belt up and over the Last remaining Pulley.
e. Before releasing the pressure on the Tensioner, visually inspect the remainder Pulleys and the Belts' Positioning on them
Posted on Apr 01, 2010
Tom W
  • 760 Answers
SOURCE: 1997 Cavalier needs serpentine belt. i need a step
It will depend on what engine
Here is a cool pdf of many belt diagrams:
http://onlinemechanical.net/support-files/serpentine_belts.pdf
page 4 of this PDF begins listings of different cars. Find yours and then click on belt number and it will take you to the page for the diagram.
Posted on Aug 18, 2010
Removal of serpentine belt on 1994 Jeep Grand Cherokee
Below is the master help link provided to go through belt routing diagram:---Timing belt, drive belt, serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all types of car models?
Click the link below: ----
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
----------This will help. Thanks.
Jan 27, 2012 | 1994 Jeep Grand Cherokee
I need a diagram for the serpentine belt on a 1997 jeep grand cherokee tsi 6 cylinder.
  • Hi, I can help.
  • Serpentine belt diagram for the 4.0 (6 cylinder) is as indicated in the diagram i uploaded below.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 22, 2011 | 1997 Jeep Grand Cherokee
I need a diagram for the serpentine belt for a 5.2L engine on a 1997 Jeep Grand Cherokee
1997 JEEP GRAND CHEROKEE - V8 5.2L 318ci GAS FI N Y
Usually the label diagram is underhood, over radiator/grille..
If you need more details about youe Jeep ZJ Grand Cherokee, can check this documents about Repair Manual: Grand Cherokee 1993-1998 FSM
To get out, it's easy and doesn't require a prybar.
  • Get a 14mm or 9/16" socket and a long handled ratchet or breaker bar.
  • Get the belt around all the pulleys except the A/C compressor or Alternator.
  • The tensioner pulley is near the Alternator toward the center of the engine. It's on a spring loaded arm. Get your socket on the center nut of this pulley.
  • Slowly pull the ratchet toward the center of the engine. The pulley will pivot on the arm allowing you to get the belt on the final pulley.
  • Slowly release the tension.
  • You're done
Hope helps (remember to rate this answer).
Dec 29, 2010 | 1997 Jeep Grand Cherokee
I need a diagram for a 1997 jeep cherokee sport for changing a serpentine belt
1997 JEEP CHEROKEE - L6 4.0L 242ci GAS FI N S
Belt Routing Diagram - Multiple Accessory, w/A.C.
1997 JEEP CHEROKEE - L4 2.5L 150ci GAS FI N P
From DAYCO Catalogue.
Hope helped with this; remember rated this help. Good luck.
Nov 18, 2009 | 1997 Jeep Cherokee Country
Replace serpentine belt on a jeep grand cher w/4.7 liter engine
It's posted inside the hood. Lift hood, look on passenger side.
Nov 16, 2009 | 2000 Jeep Grand Cherokee
I need a diagram for the serpentine belt for a 97 jeep grand cherokee
Usually the label diagram is underhood, over radiator/grille...
I hope help you with this (remember rated this help). Good luck.
Sep 21, 2009 | 1997 Jeep Grand Cherokee
Lisle Serpentine Belt Tool Logo
343 people viewed this question
Top Lisle Hammering Experts
Robert Wooley
Robert Wooley
john h
Lawrence Oravetz
Are you a Lisle Hammering Expert? Answer questions, earn points and help others
