How to unlock from iPhone s4 white cell phone and it already lock out with disable
It's a common issue. You can follow below steps to fix it.
Before trying to fix the iTunes error with some methods, you need to be sure you have the newest version of iTunes on the computer. Sometimes just updating to the newest version of iTunes is enough to resolve all syncing problems, particularly if the desktop software hasn't been updated in a while. You can always download the newest version of iTunes directly from Apple. After updating to the newest version of iTunes, if you find that your iPhone still won't sync with iTunes, you can follow the tips below to fix the error.
1. You can simply quit out of iTunes, then relaunch the app, and try syncing again. Sometimes this is enough to get your iTunes working again.
2. If syncing fails, the Sync button is greyed out and not available at all, or if you try to sync and nothing transfers over to the iPhone, iPod, or iPad, you may simply need to authorize the computer with iTunes.
3. You can also try restarting your phone by holding down the home button and power button.
4. Sometimes just restarting a Mac or PC is enough to resolve the problem and get things syncing again.
5. Typically use Wi-Fi Syncing? Try using a USB cable instead. Usually use a USB cable? Try using Wi-Fi syncing instead to see if that works.
6. If you find wireless sync to suddenly stop working, you typically just have to toggle the feature on and off again to get it functioning again.
7. Sometimes USB ports go bad, and though it's pretty rare it's very easy to rule out. All you need to do is switch the USB cable from one port to another and see if it works.
8. Reset and restore the iPhone. This should be your last option. You will lose all the data on your device. You will be resetting your phone to factory settings and start as if its a new phone. Only advantage is that you have iCloud backup.
For more details, check: How to Fix When iPhone Won't Connect with iTunes
SOURCE: iphone disabled to "connect to itunes" but needs passcode
Turn your phone off and plug it into your computer holding the home button down. That will put your phone into restore mode.
http://www.mobileease.co.uk
SOURCE: its keeps saying IPHONE IS DISABLED CONNECT TO ITUNES
Connect you itouch to iTunes.
Press and hold the power and home buttons
Screen goes black, now release the power button. Make sure you don't release the home button until it says "we have detected an iPod Touch in recovery mode."
Once it does this just do a simple restore, by clicking the "Restore" button under the large iPhone picture.
Hope this helps!
SOURCE: iphone is disabled
I read a tutorial on disable iPhone backup password, hope it help you:
http://www.windowspasswordsrecovery.com/iphone/disable-backup-password-in-itunes.html
SOURCE: Iphone disabled, can't connect to itunes
read detailed solutions on "forgot iPhone passcode and iPhone disabled" from http://goo.gl/z5CNo
