Crosley CAWC529JQ Top Load Washer Logo
A
Anonymous Posted on Sep 04, 2014
Crosley top load washer will power on and that's
Crosley top load washer will power on and that's it
Level 3:
  • Crosley Master 17,130 Answers
  • Posted on Sep 04, 2014
Crosley Master
Level 3:
Answers
17130
Questions
0
Helped
3634846
Points
52372
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect. If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash. Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8 Check this link to replace the inlet valve: http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
1 Related Answer
Anonymous
  • 105 Answers
  • Posted on Mar 16, 2008
SOURCE: Crosley caw5923mqd Top Load washer spins but leaves A LOT of water in the clothes
have you checked the pump out of the maachine
the pump may be blocked restricting water flow
if that is ok maybe you need to give the n
machine a hot wash the seals may be draging the spin down
Why won't my Crosley top load washer pass wash cycle?
There are several reasons why your Crosley top load washer might not be passing the wash cycle. Some common causes include:
  1. Power issues: Check to see if the washer is properly plugged in and the outlet has power.
  2. Water supply problems: Make sure the water supply valves are turned on and the hoses are not kinked or clogged.
  3. Load balance: The washer may not be able to advance to the next cycle if the load is unbalanced. Try redistributing the clothes evenly in the drum.
  4. Control panel issues: The control panel or the control board may be faulty and need to be replaced.
  5. Lid switch: If the lid switch is not functioning properly, the washer may not be able to advance to the next cycle.
  6. Clogged pump or drain: If the pump or drain is clogged, the water may not be able to be pumped out of the washer, causing it to stop mid-cycle.
If you are unable to resolve the issue on your own, it may be best to consult a professional for further assistance.
Spin light is blinking on my crosley washer
check belt is not Brocken filter is cleaned also can be the motor not turning check brushes or that the motor is not burned
Crosley CAW9244XQ top load washer
need a replacement plug where can I find one
3helpful
2answers
How to bypass lid switch
uplug power. remove switch, then tape the wires together. this will make a complete curcuit, so it should run. good-day !
2answers
Crosley CAWC529JQ1 top load washer sounds like a cement mixer!
sounds lik the main bearings are faulty and needs a strip down to replace parts otherwise another machine may be in order
1helpful
Top Crosley Washing Machines Experts
vince
ADMIN Andrew
ADMIN Andrew
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
