Washing Machines Logo
C
Cheryl956 Posted on Sep 04, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does LOC mean on kenmore elite washer ?
Frontloading kenmore elite washer wont turn on. Only flashes LOC. i had turned the brakers off & on for the Washer since I cant reach the plug. Nothing. Help !
Jimmy Smith
Level 2:
Sergeant:
  • Expert 198 Answers
  • Posted on Sep 04, 2014
Jimmy Smith
Expert
Level 2:
Sergeant:
Answers
198
Questions
0
Helped
56059
Points
596
Press the Options and Select buttons at the same time and hold for 3 or 4 seconds to unlock the control panel. Best Wishes
  • Gary McFarlen
    Gary McFarlen Aug 30, 2022
    For my Kenmore 417.41122410 washer, this worked perfectly! I held for 20 seconds. Thanks.
prem mathew
Level 3:
  • Kenmore Master 662 Answers
  • Posted on Dec 06, 2015
prem mathew
Kenmore Master
Level 3:
Answers
662
Questions
Helped
265264
Points
1748
Press & hold 'lock' for 5 seconds or more. The lock light should go off. Of course the machine shd be 'on'.
  • prem mathew Dec 06, 2015
    It means the machine shd not be tampered with by kids - while the machine is working. You operate the loc to unlock and lock the same way by depressing the loc button.
5 Related Answers
duby1990
Justin Duby
  • 370 Answers
  • Posted on Nov 21, 2008
SOURCE: Front Loading washer Kenmore Ht3
Here are the steps to unlocking the door manually if clothes are still in the machine.
1.Unplug machine
2.remove bottom panel
3.Reach up along the inside of the front panel and locate the botttom of the door latch assembly
4.Located on the bottom of the door latch assembly is a tear dropped shaped tab
5. Gently pull down on the tab about a 1/4 inch or until a click is heard.
6. You may now open the door.
This code means the door lock mechanism has failed or the central control unit has failed. Replace the door lock mech. first. This should fix the problem. (before replacing anything make sure there is no obstruction around the switch or in the switch.) After the machine has been unplugged it may fix itself. if not replace door lock mech.
Anonymous
  • Posted on Aug 06, 2009
SOURCE: kenmore elite HE3t
I am getting an F35 code on the washer has anyone had this problem
Anonymous
  • 15935 Answers
  • Posted on Sep 10, 2010
SOURCE: error code LOC on kenmore front load washer
Press/hold LOCK for 5 seconds.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Anonymous
  • 1902 Answers
  • Posted on Dec 11, 2010
SOURCE: Kenmore washer model44082 will not work. It
Hello
LOC error code is displayed when the control panel is locked, to unlock it press the OPTION & SELECT button and hold them for 20 seconds. This should reset the control, if it does not then replacing the control is recommended repair. Please get back to me if you have any other questions.
Kevin
Anonymous
  • 12 Answers
  • Posted on Nov 20, 2011
SOURCE: dL F this is flashing on my Kenmore Elite HE4t
Try this site:
http://adsisecurity.com/KenmoreWasher.htm
1helpful
Washer kenmore elite washer model 417.41102000 displays LOC and won't turn on. how to reset and unlock the controls?
Control Lock (Press & Hold) To lock the controls between or during cycles, press and hold the Add Steam button for 5 seconds. ' will be displayed if you attempt to wake up a "between cycle" locked unit and ' will alternate with cycle time remaining in a "during cycle" locked unit. Repeat to unlock the controls when you are ready to operate the washer. Use this feature to reduce the likelihood of accidental operation by children. 41741102000 KENMORE ELITE WASHER Manual Sears PartsDirect
Hope this helps?
Was does LOC mean
Hi Holly...your control panel maybe in LOCKED mode....
close detergent tray....press OPTIONS and SELECT
buttons at the same time for about 3 seconds to
unlock. I hope this works for you.
Regards,
Dennis
1helpful
Remove the front panel of Kenmore Elite Frontloading washer
You gotta tip it back to get to them screws on bottom panel64cf6cd.jpgf596406.jpga6e1280.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
6helpful
I have error code loc the machine won't
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
12helpful
Error code LOC on kenmore front load washer
2answers
My Kenmore Elite Frontloading HE3 is flashing a Sud, what do I do
apply a small amount of cooking oil imside tub ,, must use only HE deteregent if you are ,,, maybe too much
Alexander
vince
