It goes thru the process but gets no channels. TV now blank. tried factory reset. Antenna works on other TV.
SOURCE: HAVE LG DU-27FB32C LG TV. DO NOT HAVE A LG
There should be buttons on the cabinet to control the TV. Are the buttons on the cabinet not working?
SOURCE: my tv wont pick up any channels
have you switch the broadcast to Air from Cable using the remote go to this and also let it scan for channels auto...hopefully this will do the trick
SOURCE: Our LG 37LH5000 is just over 1 year old . The auto
When the tv is set to av1, it means the tuner is not being used, press the input/source button on the remote or tv itself. it should work fine.
SOURCE: TV has lost channel 3-1. Running auto tuning
Un-plug the set fir 10 minutes then run Auto tuning again, let me know.?
SOURCE: I tried hooking up a new RCA digital antenna (HDTV
You need to set the tuner signal source from CABLE to AIR for it to look for Digital TV signal from the AIR, the setup should be in the on screen TUNER SETUP menu.
Please leave raring if it helps.
Manual; http://tv.manualsonline.com/manuals/mfg/lg/32lg30_37lg50_37lg30_42lg50_42lg30_47lg50_52lg50_32lg60_32lg70_37lg60_42lg70_42lg60_47lg70_47lg60_52lg70_52lg60.html
