Dewalt Dc9310 7.2 Volt To 18 Volt Nicd / Nimh / Li-ion Fast Charger Logo
A
Anonymous Posted on Sep 04, 2014
DC9310 charger was pluged into a 220v by mistake. What fried and can I replace it?
tebrown507
Level 2:
Sergeant:
  • Expert 415 Answers
  • Posted on Sep 05, 2014
tebrown507
Expert
Level 2:
Sergeant:
Answers
415
Questions
0
Helped
110981
Points
506
Most likely all of the power control circuitry, charging circuitry, and voltage regulating circuitry. At this point, your best bet would be to look for a used one on line.
1helpful
Dewalt dc9310 charger flashing
On some chargers, when the light blinks rapidly, it means that the battery is bad. Try looking up charger information on-line.
1helpful
Can i use 220v source to energizer charger chvcm4
you will need a reducing transformer 220volts to 120 volts, you can find one at Radio Shack or Fry's Electronics., European countries uses 220volts, and the plug configurations are different from those of the USA.it is recomended to take one of these transformers with you when you travel abroad.
My turntable doesn't rotate any more...
Hi, the transformer that supplies power to the motor has been fried by the 220v input and will need to be replaced. If you remove it and go to your local electronic parts supplier they should be able to sell you a replacement. Cheers John styluscity.com
I have just purchesed some new milwaukee cordless power tools and have pluged it into 240v when it should have been 120v .Now it wont work any idear;s
Sorry to say that you probably have fried the charger and maybe any battery that you plugged into it.
While you might get lucky and be able to repair the charger yourself, they are considered sealed units that aren't intended to be opened up for repair. My advice would be to replace the charger instead of trying to fix it. But if you do open it up, what components you find inside (transformer, caps, etc) will probably be easily identifiable by the blackened leads.
My ex-wife who was Russian, plugged my mothers vacuum into a 220v heater outlet and although I did manage to repair it, I would have been money and time ahead to replace it instead of spending the time and money to repair it myself.
My new Epson Stylus NX400 was plugged in 220V by mistake and does not turn on any more. Is it possible to fix.
Fried the power supply
Can it be replaced at a cost that may be more then a new one.
It might be like making white bread out of toast.
1helpful
What will happen if I plug my 110V tv into a 220V receptacle?
If you want to fry your electronics or appliances that's it's a sure way to accomplish that.
While appliance working ONLY at 220v will just not work or under perform (like a hair drier) when plugging electronic equipment that runds ONLY at 110v then that item will be "fried" as all its electric components will be burnt as it will receive twice the power that it was build to receive. Should that happen the safety switch on the 220v circuit where the item was MISTAKENLY plugged will be triggered (hopefully or there will be risk of fire and serious injuries, even death) and the power will be shut off. That's a major but possible mistake.
If traveling abroad those who come to US will unlikely damage their appliances (like electric razors) as they will receive less power (110v vs 220v) and usually these items are protected against these mistakes by the specifications of their own design. The opposite is not true of course as just mentioned above.
So do not play around with dangerous items please! ;) On a positive note though: Nowadays most appliances have dual power and should work whether plugged in a 110v, 60Hz (most common in US) or 220v 50Hz (most common in Europe). So nothing really happens... it just works as long as you have the proper adapters to plug the appliance to the different receptacles.
Note: One of the differences is that (without going into the math of it all), an appliance working at 110v will draw x2 times the power than it draws when working on 220v so if an appliance was drawing 3A at 110v it will only draw 1.5A when working at 220v.
Best.
The 110v transformer was inserted into 220v socket!
You have damaged the system beyond economical repair. There are so many components inside that have fried that it is impossible to repair. Sorry. That's what happens when you overvolt an electronic circuit.
Top Dewalt Electrical Supplies Experts
Stan Ford
CJ Rock
CJ Rock
Al Taqah Al Sareeah...
Level 1 Expert
Are you a Dewalt Electrical Supply Expert? Answer questions, earn points and help others
