Yes, but they don't like it. I've been there a few times and what the bills like more is getting paid and care less who _Ned
_ ends up being owed. Good Luck.
My range was doing the same thing. I finally called the Consumer Protection Agency and reported it. It launched a national recall. With their help, Frigidaire replaced my range. On Easter 2014, the new one did the same thing. Burner turned on by itself, to 8.5 with knob in the off position. We had to unplug it. Frigidaire once again did not care. I contacted the CPSA again - they are investigating. I will NEVER have another Frigidaire Range. Check your model number against the recall information. Don't trust it! It is a fire hazard.
All stoves have a gas shut off valve. Make sure your gas dryer still works because you paid your gas bill. Yours might be located under the stove or in the basement.
put in kitchen sink with hot hot water over night, with dish washing liquid. preferbly when kitchen is not being used. (After dinner time) drain then spray with mr muscle oven cleaner give it about an hour, then scrub the **** out of them with a stainless steel goldilocks. Rinse then soak in hot water again for 20 minutes then drip dry. After use when cooking always clean any mess left behind. Wipe down so it is easier for you to wash when needed.
pull of the knob
put a smill flashlight down the selector shaft
you should see a small adjustment screw
probably a tiny flat head
very small turns
start from the lowest setting if you start from the highest you could loose your low flame below the grid
always adjust fromt the lower settings
some of these units are factory set and cannot be adjusted by the consumer,,,,unless you want to install new adjustable gas valvews
I used Mr. Clean multi-surface and the green, back side of the sponge. Turned on a light to show visible stains better, and scrubbed away. It didn't scratch the glass and got it out quick. Hope this helps.
