GE Energy Star WCVH6260F Front Load Washer Logo
k
kim chappy Posted on Sep 05, 2014
I dont have a option button just power and start i have a red lock symbol on and washer wont start
My IFB washing machine displays CH, What is the error?
On some IFB washers, the CH indicates that the child lock (control panel lock) has been activated to avoid accidental washer use. On the IFB digital 5 KG washer, you can toggle the child lock on and off by pressing the Soak Option and Delay Start buttons simultaneously. These are the second and fourth button for the Optional settings above the LCD display on this model. Below the keys, there is a skeleton key symbol in the center of a line drawn between these two keys. You can see this information in the manual for this machine in the manual, http://www.ifbindustries.com/home_appliances/washing/manuals_new/DIGITAL_5_KGS.pdf . See page 9 (7 of the PDF) and page 13 (page 11 of the PDF).
I hope this helps. Please add a comment with your model number for information specific to your washer. If your washer uses a different set of keys to toggle the child lock on and off, you should look for the skeleton key symbol on the control panel housing. Any response to a follow-up comment may be delayed.
3helpful
A red padlock symbol is showing on the panel of my WCVH6800 front load washer. I can't change any of the wash settings. How do I fix this?
Here's what the Padlock represents:
Lock Function
You can lock the controls to prevent any selections from being made. Or you can lock the controls after you have started a cycle. children cannot accidentally start the washer by touching pads with this option selected.
To lock the washer, press and hold the DELAY START button for 3 seconds (on some models use SIGNAL button). To unlock the washer controls, press and hold the DELAY START button for 3 seconds. The control lock icon on the display will light up when it is on.
NOTE: The POWER button can still be used when the machine is locked.
2answers
Key Symbol appearing and cycle wont start
Please see if there is a lock installed into for safety. Press and hold power/start/pause as power is plugged.
Make sure that the door switch is working open and close once again to check as this can also stop the machine from operating.
2helpful
My tv logik lk 74n has locked. please help me procedures of removing the padlock symbol.
The Red Lock indicates that it has been Child Locked, this could be done by accidently pressing child lock. On your remote control there is a MUSIC button, to turn off the red child lock PUSH & HOLD the button. The red lock does not go off with a qucik push. You need to Push & Hold The music button for about 10 secounds.
Read more: How to unlock my logik tv , it has a red lock on the corner with a blue screen and i cannot use my remote or the keyboard to activate the menu ' Answerbag http://www.answerbag.com/q_view/516852#ixzz289vnGLRC
1helpful
The water switch to the washer wasnt turn on due to no water going to the washer from the hose it was blinking red H symbol I tried to cancel load to restart and machine stays on and wont start new cycle...
Just unplug the washer and wait a couple of minutes before you plug it back in. That should clear the code and let you get the door open.
Hope you find this Very Helpful and best regards!
3helpful
2answers
C45072 Kenmore washer will not start. Did one
I've been going crazy with this too. Turns out all you have to do is hold down the "options" & "select" buttons at the same time until the "lock light" (the light just above the "pause/cancel" button) turns off. I guess that's why there is a line under the option/select buttons that have a lock symbol connecting the two.
Cheers!
8helpful
2answers
Kenmore front load washer 970-c45072-00
We had the same problem and this website solved it for us. The child lock is on when the lock symbol light in the lower right of the panel is on. The machine will not start with the light on. If you press the Option and Select buttons together (there is a lock symbol with a line to the two buttons), the lock symbol light will switch between on and off. When it's off, the machine can start. None of this was in the "Use and Care Guide," maybe we lost our manual. But thanks for helping to solve the problem!
Top GE Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Virgil Watts
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
