Faded vertical line only with cyan color
SOURCE: RICOH CL7200 MAGENTA AND CYAN LINES ON COPIES
I would actually start with the cleaning unit right below the transfer belt. If it's worn out, it often streaks colors even after you've replaced the PCUs. As for the Calibration failure, I would make sure the chrome like roller underneath the transfer belt is clean. The sensors look through the transfer belt and reflect off this roller.
SOURCE: lines in printed copy on Ricoh CL3500N
Depending on the age of the model, it could be a couple of things. ***Never touch the drum or expose it to bright light*** The drum unit is bad. It's the shiny brightly-colored large roller in the center of the machine. On most recent smaller machines like this on it's integrated into the toner cartridge. Check it out. If it has toner build up on the ends, it's bad. or The corona wires need cleaning. Some machines have a small slide that moves from one side of the printer to the other which cleans the hidden corona wires. It's usually brightly colored. The corona wires are also integrated into the toner cartridge in many smaller machines
SOURCE: ricoh sp c410 yellow toner is offset in prints
Go into the menu that says maintence )I think) and do the color registration.
SOURCE: A series (10) vertical lines on print outs
See Charge roller my be dirty or Catriges PCU Units
SOURCE: Ricoh SP C811DN error sc549
unplug printer, wait minute, plug in, should reset.
check Ricoh website to trouble shoot if does not reset.
Memory chip at TD sensor: Communication error
Retry of memory chip communication fails three times after the
machine has detected the memory chip communication error.
?? Damaged memory chip data
?? Disconnected inter face
?? No memory chip on the development unit
?? Noise
Replace the PCU.
