Proscan 32LB30QD 32 in. LCD TV Logo
A
Anonymous Posted on Sep 05, 2014
Flatscreen tv picture has shrunk to the upper left side of the screen
Chris Frost
Level 3:
  • Master 985 Answers
  • Posted on Sep 07, 2014
Chris Frost
Master
Level 3:
Answers
985
Questions
0
Helped
218256
Points
3239
The TV is in Picture-in-picture mode. The small picture is the last active source. The bigger area is the current source connection, but there's no signal.
Read the manual about how to operate the Picture in Picture feature.
Sanyo DP22640 television that has shrunk on both sides?
If you have already tried replacing the mainboard and it did not fix the issue, then the problem may not be related to the board. Here are a few other potential causes for a TV screen to shrink on both sides:
  1. Picture settings: Check your TV's picture settings to ensure that the aspect ratio is set correctly. If the aspect ratio is set to "zoom" or "wide," it can cause the picture to appear smaller on both sides.
  2. Overscan: Some TVs have a feature called "overscan" that can cause the edges of the picture to be cut off. Check your TV's settings to see if there is an overscan option, and if so, turn it off.
  3. Defective panel: If neither of the above solutions works, it's possible that the issue is with the TV's panel itself. In this case, you may need to have the TV professionally serviced or replaced.
It's also worth noting that shrinking on both sides can sometimes be a normal behavior for certain types of content, such as older movies or TV shows that were originally shot in a different aspect ratio. In this case, the content may simply be displaying as intended.
I have a 1996 Panasonic tv #CT 20621U. Great
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
On sony kv-24fv10 is small and on the upper left of screen
Check and replace damaged component/s at its pincushion correction circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
TCL L46E5300F flatscreen half right side screen is darker than left side
If it is an LED LCD TV, the backlight inverter board should be troubleshooted. Contact any service technician.
I have a LN46A550 flatscreen...the picture is now only in the upper left hand part of the screen. It's basically 1/6 of the screen. I have tried to pull up the PIP function on the remote and it will not...
there should be a ratio button on the remote if not its deffinitly in the main menu click on 16/9 wide screen you seem to have the veiw secound channel working on you set but were is the big picture of the current show? anyhow try that and let me know how you went
merry christmas
54" Sony Wega made a loud popping sound and now has Black lines
When I got my new LCD big screen, it had a black line across the entire width. It looked like the screen was pinched.
They claim that it can be repaired but that repair costs as much as a new tv.
My tv was replaced. Hopefully your warranty is still in place to get the unit replaced.
3helpful
2answers
We have sound but no picture on Phillips flatscreen television
Take a flashlight and shine it on the screen when you have sound, look very close, can you see a video image? If so the inverter is probably bad.
Let me know and I will assist further.
lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Av-32f476 picture shrinkage
I had a Crummy Westinghouse TV that had a problem like this. JVC's are typically better built then a Westinghouse. My first educated guess - sounds like it's a voltage issue, most likely on the high voltage. Probably a capacitor on the power supply side of the motherboard or the capacitor in the flyback transformer. Just and educated guess.
3answers
TV PROBLEM
No sir its not just an adjust ment or "twiddling" It sounds like its one of the same as your girlfriends set except a differant part such as a capacitor in the vertical curcuit, Output IC or even a defective resistor?? Good Luck
Top Proscan Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
