HP LaserJet 4350dtn Printer Logo
A
Anonymous Posted on Sep 05, 2014
How do you fix an "opc-at-end-of-life" message
Mark Schmit
Level 3:
  • HP Master 1,915 Answers
  • Posted on Sep 06, 2014
Mark Schmit
HP Master
Level 3:
Answers
1915
Questions
0
Helped
753978
Points
7967
This is not a message you would ever see on an HP printer. You will only get a "cartridge empty" error. In most cases you will need to replace the drum unit on the printer.
I just install a new opc belt in a xante colourlaser 1200 printer, it still say install opc belt.
You probably need to go into the menu structure and find the resets menu. It could be under machine info or maintenance. When you have found the reset menu or parts life, you should be able to reset the OPC Belt.
1helpful
Hp laserjet P4015 OPC is near end of life message
just replace print cartridge or recycle and continue using it and service printer/kits and pickup rollers or replace them
3helpful
What does OPC stand for on the xante illumina press? I am getting a message saying the OPC is near end of life.
It stands for Organic Photo Conductor or also known as Laser Drum.
Thank you for visiting FixYa! We answer your concerns promptly for FREE. Please spare a few seconds to click on YES button in return. Have a good one!
OPC belt is replaced and has 100% life but the OPC
make sure all components are properly seated. also try turning the printer off and waiting a few minutes and turn back on.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
MFC-9420CN All-In-One Laser Printer Install OPC belt message
Perhaps your OPC belt is at the end of its life and needs replacing
Brother MFC 9420cn printer message
Check to make certain that the OPC belt is both seated correctly and that it is not damaged as even though it may have what you consider to be sufficient life left in it, if damaged, it needs to be replaced.
Drum Cartridge Warning won't go away
Replace the fuse on the bottom of the drum cartridge.
1helpful
Is the massage replace the cg belt the same as the ocp message as i can't see any damage to them at all.
You are correct the 'Belt CG' is the OPC belt cartrige. The mesage advising this item needs to be replaced comes up as the result of a page counter in the printer. The mesage comes up as a result of the page counter exceeding the maximum number of pages expected from the OPC, ensuring reliable print qulaity.
The message does not indicate the OPC Belt is damage, it has reached the end of its designed life.
129helpful
4answers
MFC-9420 Replace OPC Belt message stays on after replacing belt
As far as the OPC belt - don't replace it until you start seeing ghosts and image defects! Reset it by:
Press 1 and 7 at the same time
Press 1 to reset the life counter.
k24674
Grand Canyon Tech
Grand Canyon Tech
