Frigidaire GLTF1670A Front Load Washer Logo
A
Anonymous Posted on Sep 05, 2014
Can you tell me what size capacity this front load washer is?
  • Official Brand Answer 2,267 Answers
  • Posted on Sep 08, 2014
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1289908
Points
2557
Good Morning Friend, that's a great question!
In order to provide you the correct size capacity of your Frigidaire front load washer, I would need your model number please. You can normally locate the serial tag (which lists your model number) on the upper front, as you open the door. Thank you and I look forward to further assisting you! - Z
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
2answers
For a king size bedwill colossal size wash a quilt
yes I would say these machines will wash this item
should be gentle cycle and max water level settings.
I can confirm kenmores xtra capacity machine does.
If material is delicate or fragile any, the large frontload
machines at local laundromats will be appropriate for this job.
hope this info will be helpful, PAUL Douglas Calif.
What size washing machine is this
Your Maytag Neptune MAH6500A Front Load Washer has dimensions:
Width : 27"
Depth : 29"
Height : 42 1/2"
Capacity : 3.34 cu. ft.
http://www.ajmadison.com/cgi-bin/ajmadison/MAH6500AWW.html
2helpful
What is the capacity size of washer model fws1339ac1
Dimensions/Weight/Electrical Height: 43 5/8" Width: 27" Depth: 27" Approximate Shipping Weight: 180 lbs. Electrical Requirements: 120V/60Hz. Features Control Location: Top Console Capacity: Super Capacity Tub Size (cu. ft.): 3 Agitator Style: Twin Spin Cycles: 13 Wash/Rinse Temperature Combinations: 3 Motor Speeds: 2 Heavy Duty Motor (Hp): 3/4 Total Front Serviceability: Yes
What is the capacity (Size) of the Speed Queen Marathon Washer?
Pi,r,squared times height. Remember math back when we didn't have computers? So that's 3.14 x radius(half the distance across drum)squared(times itself) times height or depth of drum. Remember to do radius times itself first, then Pi, then height.
Type of detergent in front-loading washers
yes make sure the box of detergent says HE on it. and read the directions on the soap box for load size and amount.
1helpful
2answers
What is the capaity of 2005 Kenmore Elite Washer and Dryer, models 110?
Starting in early 2002, the capacity sizes were changed around a little bit. A normal sized washer now all have the same sized tubs (pretty much) in the 110 series (Whirlpool Manufactured) washers. The capacity is now rated somewhat by the agitator action the washer comes with. Depending on the type of agitator you have, will determine the capacity. King size capacity means you have a pretty good capacity (size wise) than others. You have normal capacity, large capacity, super capacity, king capacity, and I even think they have canyon (yes canyon) capacity. Capacity sizes dont really mean to much though. In order for you clothes to get clean, the must have room in the tub to move. The must be able to float up, then get pulled down by agitator action. That should determine the size of what goes in the washer. Always use same type clothing when doing laundry (i.e. towels with towels, sheets with sheets, etc, this will keep the load balanced better). Watch what you load, comforters are ok (per manufactures ok) but I do not tlike the idea unless its a front loader, and only by itself. Let me know if this helps you out any.
1helpful
WHAT IS THE LOAD CAPCITY SIZE OF WASHER MODEL 110.20702990
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
