SOURCE: 1999 ford tauras transmission and speedometer
Replace the speed sensor on the trans that will cause exactly what you describe is happening.
SOURCE: won't shift out of low,speedometer doesn't work
see my comments, not 100% sure that it was the out put speed censor or not, but after reconnecting the wires to a new censor and reconnecting the battery and clearing codes it worked. connection was not clipped may have been loose
SOURCE: 94 dodge neon auto tranny
Here is some possible reasons why your transmission is having those problems .
* The gear shift linkage is binding
* There is an internal problem in the transmission
* The throttle cable is broken or disconnected
* The vacuum modulator on the transmission is faulty or the vacuum line is damaged
* The electronic transmission control circuit may be faulty
SOURCE: speedometer not workin at times. Not shifting into
wont shift out of first gear, engine races and speedometer isnt moving and all fluids are full on 2000 dodge caravan
SOURCE: My H2 2003 hard or take time to shift when running to 35+ MPH
check your tranny fluid and filter. you may have a clog some where or could be low on tranny fluid.
