Why does my CD player keeps saing no disc when I try to play a CD?
SOURCE: Sony CD/DVD Player DVP-NS50P not playing my avi files DVD+RW
You need to convert avi files to dvd format before burning, otherwise the player won't recognize them. Google "avi to dvd" and you'll find a number of free or pay programs that will do the conversion for you.
SOURCE: Disney dvd player wont play movies (dvd) but plays music (cd) fine
Might be the type of movie - some of them are only able to play "G" ratings. Try this: click <play> 1234 <play> It will likely unlock the dvd that is in and will begin to play. You will have to do the 'code' each time, or there's an unlock program you can purchase.
SOURCE: Polaroid PDM-0711 DVD player won't play DVD's but still plays CD's
I've got the same problem, I turn my player on it's side until it reads the disc. more of a band-aid solution.
SOURCE: My dvd player dvp615 doesn´t play dvd discs. only music cd´s
The unit has two lasers one for the cd and one for the dvd, the one for the dvd is bad and the whole laser assembly needs replaced. Cheaper to buy a new player.... sorry
SOURCE: Plays CD but not DVD, says no disc
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more.
