My nikon coolpix l18 won't power on. I've replaced the batteries and it's not hooked up to my tv or pc. This happened when I had it powered off when I was recharging my batteries and now it won't turn on, does anyone know what's going on?
SOURCE: Nikon Coolpix 2100/3100/3200 battery compartment door latch broken (again)
I just purchased a new battery door for $15 with shipping from nikon. They sent a simple assembly diagram and I was able to replace the door in 30 minutes. I used a dremel to cut the old door off, but you dont have to do that. I got a little impatient.
Just buy the plastic piece and u can reuse the metal parts for your old battery door.
SOURCE: Nikon Coolpix L18 Driver
You don't need the disk to transfer your pictures from your camera to your computer. Just take your sd card out of your camera and plug it into your computer. A folder with your pictures will appear on your computer. Copy them to a different folder on your computer, so you can take your sd card out and still have them on there.
If that doesn't work, plug the cable in that came with your camera, and hopefully that will work.
I hope this helps. Please rate my solution.
Try this, it may work without the software. Turn off the camera. Plug the usb cable between the camera and the computer. Turn on the camera. If a box pops up on the computer asking what you want to do, scroll down and see if there is an option to view pictures. If a window opens up with all your pictures on it, great. Now open up a folder where you want to put your pictures. Bring up the other window with the pictures in it and hit the control key and the d key at the same time on your keyboard. Then drag your pictures to the window where you want them and let go of the mouse key. They should all move over. Then you can use Windows image viewer to see them. Let me know if that works.
SOURCE: NIkon coolpix L18 horizontal lines appear after taking picture
contact NIKON BAD CCD PROBLEM !
Get ir repaired free of charge just call them thousands face the same problem and all brands are repairing it free go call them
see the link for widespread Bad CCD problem dont worry if u are not on list but u have the same problem call them PLS RATE ME FIXYA for help !!
http://www.imaging-resource.com/badccds.html
SOURCE: Nikon Coolpix L18 will not turn on.
this is the problem go for repairs Free of charge
http://www.nikonusa.com/Service-And-Support/Service-Advisories/COOLPIX-L16-L18-Service-Advisory.page
pls remember to rate me FIXYA fo rhelp
